Temperature based fan speed control
ericgibbs
Joined Jan 29, 2010
21,601
hi ako,
Welcome to AAC.
What is the purpose of the 10u in the Base of the 2N2222.
Do you have a Arduino sketch you could post.?
E
Dodgydave
Joined Jun 22, 2012
11,395
Ok are you getting a 5V output in the Blue feed to the 1K resistor?
If yes the check the transistor if no then there's something wrong with the Arduino and input.
Ya’akov
Joined Jan 27, 2019
10,330
As @ericgibbs mentioned, seeing your code is important. There are two parts to this problem and you have only provided (some of) one of them. Photos of your actual wiring would also help to eliminate a lot of blind questioning.
