TEKTRONIX 475 oscilloscope power problem
AlbertHall
Joined Jun 4, 2014
12,652
Collector of Q1316 at -3.2V is much lower than the marked value of +1.6 which suggests the oscillator is being driven harder.
However, there is a diode to ground connected there (CR1316) which should prevent any voltage lower than -0.7V or so.
I can't see that it would cause your present problem but do check that diode.
Can you get the 20MΩ resistor?
reptooyep
Joined Sep 29, 2016
25
Oh i should have been drunk last night cause i did not take the good measurement.
On the base of Q1306, i measure 0.76v. it's a little bigger than on the shematic but it sounds good.
This problem drives me crazy.
The 24.5M resistor is not changeable. it's a kind of plastic plate with 3 resistors (R1303A, B, C).
I tryed to add 180K but it does not change at all.
Do you think it can be a material problem ? Everything else seem to work, exept the vertical adjustements which is totally
untuned.
Thanks
reptooyep
Joined Sep 29, 2016
25
Finaly,
i made measurement of the resistor and i get 14.5M... I don't understand cause i wasn't able to measure it.
So, i add a 10M just before the base of the transistor and then, the bulbs are flashing and with minimal brightness, i can see clearly the lines.
After few measurement, something near Q1316 has burned (maybe the Q1318 again) so, i'm back to the starting point...
Maybe i've touched two componment with my multimeter stick. I'm waiting for a new Q1318 (2n3055).
Too bad for me
AlbertHall
Joined Jun 4, 2014
12,652
Just to be clear, R1303A in parallel with 20MΩ reads 14.5MΩ? If that's right then R1303A is 52.7MΩ (should be 24.5MΩ) and that is certainly your fault.
Where did you add the 10MΩ
reptooyep
Joined Sep 29, 2016
25
With 22M in parallel, i read 9.2M.
So, my R13.3A = 14.5M.
After this, i unsoldered the parallel R and read back R1303A = 14.5M (maybe i did it wrong before).
So, i added a 10 M in serial in order to match the 24.5M.
I think i'll wait for my new transistor before doing wrong again
AlbertHall
Joined Jun 4, 2014
12,652
When you are reading 14.5MΩ, is at least one end of the resistor disconnected from the rest of the circuit, because it must be to get a correct reading.
reptooyep
Joined Sep 29, 2016
25
I disconnect one end and get about the same result but the value is always changing. I'm not sure my chiness meter is good for big values.
reptooyep
Joined Sep 29, 2016
25
The resistance change and become stable after a while. What is sure is that you point the problem pretty well.
I don't know how i'll fix it cause this resistor will not be easy to replace.. i have only big values 1/4W..
AlbertHall
Joined Jun 4, 2014
12,652
You could replace it with a string of lower values in series to make up the total required resistance. You will need to be sure of the voltage rating of the resistors and the actual voltage they will get in that string. You also need the space to be able to do that and make sure it is all well insulated against 2.5kV. The power rating of the resistors is not important. The total power in the original resistor is only about 1/4W.
reptooyep
Joined Sep 29, 2016
25
I'm aware of that. I'm a noob for scope but have good skils in electronic (metal detectors and avr projects).
I'll loof for a replacement for this resistor
reptooyep
Joined Sep 29, 2016
25
I can add 4.5M to my 22M and put some shrinkable tube, it will be very much smaller than the original one...
And then, replace the transistor.
I'll post the result soon.
AlbertHall
Joined Jun 4, 2014
12,652
Is the 22MΩ rated for at least 3kV to include a safety margin? Most common resistors are 300V-500V and you would need at least 6 of these to be able to withstand the voltage.
