Technics SX-PR603 Digital Piano
emmet422
Joined Sep 1, 2024
58
shoulda quit while i was ahead. … trying to juggle the two probes was more than i could deal with.
One of the ground clips from the probe popped off and shorted something on the main board. It worked a few minutes after that, but then died.
Now there is no screen display, nothing on the control board lights up
the power light is on, and the 15 v test point are fine. The AMPL and AMPR channels just look like messed up noise pulses.
very bummed. Time to look for a replacement board?
I want to express my great appreciation for the time and effort you put in to help. And apologize for this giant step backwards…
35,087
Sorry to hear about the setback.
I was supposed to mention that extra care was required when working with open circuitry because a slight slip with the probe can make things worse. I have seen this happen too often here on AAC. Then I forgot to say it.
Let's take one step at a time to assess the situation. Hang in there.
emmet422
Joined Sep 1, 2024
58
Hanging in there. next steps?
i was very confused by the ‘slow death’ of the circuit- it worked for a couple of minutes after i shorted something , suggesting a residual charge on a capacitor keeping things alive…
emmet422
Joined Sep 1, 2024
58
I pulled out the B (Asub) board to get the probes in. slight hum from instrument.
on CN6, measured the following
“-15A”. -25mV
“+15A”. 0
-Vcc -.43V
+Vcc +180mV
on the main board, next to the diodes,
Vcc are +|- 40V dc
35,087
Post sharp photos of this section of the MAIN board, from different angles so that we can see the writing on the board.
35,087
BTW, make sure that your DMM is set to measure DC voltages. 200 VDC range is good enough. One decimal place is good enough.
Measure voltages at both legs of R28 and R29 power resistors. Expected voltage is +40 V.
emmet422
Joined Sep 1, 2024
58
R28a +.24 V dc
R28b .24
R29a .24
R29b 40
there were voltages present before i turned on power…as much as 20V????
35,087
Ok. Next test.
Unplug from power.
Measure the resistance across R28 and then across R29.
Expect to find R29 is open circuited.
emmet422
Joined Sep 1, 2024
58
Ok. Next test.
Unplug from power.
R29, as predicted, is open circuited
looked like 2W, 2 ohm; closest ceramic resistor i found was 5W.
R28 measures 2 ohms
