Off hand, the signal originates back in the x3xx section at the push-pull output transistors, An unlikely combination of things could have caused it to blow, like the output transistor in X3xx shorting and the opposite polarity input transistor AND diode shorting would place 120 volts across the resistor resulting in a 200 mA current flowing through a 560 ohm resistor .... and 22 watts later ... we see the results in the picture. But that is my active imagination speaking. I'll have to re-read the thread to see if that type of scenario was possible.I never could understand what would cause R402 to get blown away.
Here is the listWorking on next step. Reading over all posts.
Make a list of all components not installed.
Affirmative about the pictures.Your photos in the past have been very clear and extremely helpful.
In future there is no need to take pictures unless requested. For now just report what you see.
(When you do take a photo, take a second photo from a different angle because the part identifier is often hidden by a component.)
Apply power and note any indication of the three lamps glowing.
As usual, watch and smell for sparks, smoke or fire.
All voltage measurements are with respect to ground.
Measure voltage at IC401 pin-4 and pin-8.
Measure voltage at IC402 pin-4 and pin-8.
(Just checking. Don't be alarmed if you observe discrepancy.)
Measure voltage at R428 and R430 (both legs).
We are expecting to see
IC402 pin-8 +7.8V
IC402 pin-4 -7.9V
IC401 should not be receiving any power.
I checked the adjustments now, we have earlier turned them all fully counter clockwise.Yes, specifically the part about doing this before any repairs.
The ICQ adjustments, or misadjustment, can cause excessive current that would exceed the power rating of the R505/R506 resistors.
Yes it is. Just had a pause in about a year after post 418... time sure fliesTo avoid reading the whole thread, just arrived. Is it still the same Technics mentioned in the OP in 2017?
| Thread starter | Similar threads | Forum | Replies | Date |
| A | Technics SU VX-800 with blown components (another one) | Technical Repair | 139 | |
| T | Technics SU-V450 not powering up properly | Technical Repair | 1 | |
| K | Request for help in repairing Technics SU-V90D | Technical Repair | 126 | |
| R | Technics SL-PJ1 CD player | Technical Repair | 53 |
