Technics SU VX-800 with blown components (another one)
35,315
Continue testing with 1 kHz sine wave input and with loudspeaker connected. Put a 470 μF - 1000 μF capacitor in series with the loudspeaker to protect the loudspeaker. Keep the VOLUME control low to show moderate distortion.
Show the oscilloscope signals at the base and emitter of Q504 and Q506.
Test at resistors R510, R512, R514 if these are safer to reach.
Were Q504 and Q506 ever replaced?
Q504 2SC3944
Q506 2SA1535
With the power off,
check resistors R516, R518, R566, R568 in-circuit (all 2.2 Ω)
check resistors R548, R550, R570, R572 in-circuit (all 0.22 Ω)
alprampo
Joined May 29, 2026
74
No, Q504 and Q506 were not replaced. I removed them from the PCB and tested them with a component tester, and they passed. the tester is below,
However, since the test current on these multi-function component testers is extremely low, could be sometimes give a false positive under actual circuit conditions, so I will try to replace if I have spares that can be fit.
Update will come.
Thanks
alprampo
Joined May 29, 2026
74
Q504 2SC3944
Q506 2SA1535
With the power off,
You hit the nail on the head!
The resistors themselves were fine, but after inspecting the PCB under a magnifying glass, I found both R514 cracked pads/traces in that section. I repaired the traces and reinstalled the board.
I powered the unit through the Dim Bulb first, and everything looked stable. I then switched to direct mains power and injected the 1 kHz sine wave into the input.
When checking the speaker output on the oscilloscope, I noticed a strong high-frequency oscillation superimposed on the signal, making it impossible to read the 1 kHz sine wave cleanly.
Could this high-frequency oscillation be caused by the replacement transistors for Q428 and Q430? The ones currently installed have a lower Transition Frequency ($f_T = 100\text{ MHz}$) compared to the original parts ($f_T = 200\text{ MHz}$).
Update on Audio Test:
I tried connecting a speaker and playing music/audio. To my surprise, the sound coming from the speaker is completely clean to the ear! I monitored the temperatures for a while: nothing is overheating (drivers and power transistors remain cool), and there is no sign of thermal instability or smoke.
However, the thick high-frequency trace is still present on the oscilloscope.
Thanks!
35,315
Try to use your oscilloscope to find where the oscillation originates.
Is it before Q502 or after Q502?
C506, 0.1 μF would have suppressed oscillation.
alprampo
Joined May 29, 2026
74
I checked Q502 with the scope, and the high-frequency oscillation is present on both the base and the emitter.
A key detail: the oscillation only triggers when the speaker switch is engaged (connecting the load). Once triggered, switching the speaker back OFF does not stop the oscillation—it remains active, though its peak-to-peak amplitude decreases slightly.
Looking at Q428 and Q430:
  • Oscillation is present on both transistors, but the amplitude is significantly higher on their emitters.
On IC402:
  • Pin 5 remains completely clean.
  • Pin 6 and Pin 7 both show high-frequency oscillation.
All these tests were performed with no input signal and the volume set to minimum (0).
Thanks!
35,315
There is negative feedback from the power stage output to IC402 pin-6.
You need to check C508, C518 (0.068 μF) and R520 (I cannot read the value, 10 Ω 1/2W ?)
Try temporarily, 0.01-0.1 μF from R570-R572 node to GND.
alprampo
Joined May 29, 2026
74
Sorry for the long silence—family comes first, and I prefer not to do any testing when I'm tired (too high a risk of letting something go up in smoke!).
I finally performed the test by adding a 68 nF capacitor from the R570/R572 node to GND.
A strange behavior started: high-frequency oscillation appeared on the left channel as well.
I also checked the components:
  • R520: As you suggested, it is listed as a 10 Ω, 1/2 W resistor on the parts list and tests fine. However, while it is the bundled component, visually it looks more like a 1/4 W resistor rather than a 1/2 W one.
  • Capacitors: In-circuit measurements match the left channel. C518 (and C517) reads around 128 nF (left channel is 132 nF), and C517/C518 show consistent values (about 2 nF)
Thanks!
Alberto
alprampo
Joined May 29, 2026
74
A small update,
I tested C508, C518 (0.068 μF) and R520 after removing from board.
Replaced Q4228 and Q430 with original ones, no change, HF signal still there.
Thanks
alprampo
Joined May 29, 2026
74
As a temporary test, try putting a 0.1 μF from C508 (R570, R572, L502 node) to GND.
See if the frequency changes.
I performed a test using two 68nF capacitors in parallel. I soldered one end to the jumper going to the node formed by R570 / R572 / L502 / C508, and connected the other end directly to power supply ground, not chassis, is that correct?
(Please let me know if this connection point is correct or if its exact physical location on the PCB could affect stability).
Interestingly, the oscillation behavior is strongly influenced by the speaker selector switch. Since the load is connected to Speaker Output "A", I expected no signal or load interaction when selecting "B" or "OFF". Instead, all four switch positions yield different results on the scope:
  • Speaker OFF: The HF oscillation is present, but at a reduced amplitude
  • Speaker A (Loaded): The oscillation triggers at full amplitude.
  • Speaker A+B: Each position modifies the waveform/frequency of the oscillation differently, even with no speaker
Speaker B (No speaker connected)
Thanks!
alprampo
Joined May 29, 2026
74
What do you mean by Speaker A, Speaker B, and Speaker A+B?
Is that referring to the Left and Right channel speakers?
No, all test have been done on R channel,
I mean moving this switch:
Could it be a waste of time checking these capacitors?
Thanks!
35,315
Yes. I think it would be a waste of time to test capacitors.
A better test would be to add about 0.1 μF from signal to GND along the signal path and see how it affects the frequency of the HF oscillation.
I think this is related to feedback. Sorry, I cannot put a finger on this at the moment (meaning, I don't have a clue).
alprampo
Joined May 29, 2026
74
Thank you so much for all your time and help! I would never have gotten this far on my own.
Regarding the test with the 0.1 μF capacitor:
Does the lead length affect the test results? In other words, can I use test leads/alligator clips, or should I solder the capacitor as close as possible directly between the nodes and ground?
Also, is the amplifier safe to use in its current state, or could this high-frequency oscillation be dangerous to the amplifier itself or the connected speakers?
Thanks again for everything!
Alberto
35,315
Lead length can affect the test result. Do not use test leads/alligator clips. Keep the leads on the capacitor to less than 1-2 cm.
I cannot say with certainty but 1 Vrms at 400 kHz should not be a problem.
I would prefer to find the source of it and eliminate it. Something is oscillating where it should not.
alprampo
Joined May 29, 2026
74
Hi again!
Update:
While probing to trace the origin of the oscillation, it suddenly stopped on its own. However, the amplifier is no longer passing a clean signal—it is now distorting/clipping again, this time with
and without load seems worst
I'm pretty sure I didn't cause a short with the probe this time. To rule them out, I replaced Q516 and Q518, but they were fine (no change in behavior).
Since the oscillation abruptly disappeared at the exact moment the signal degraded, I suspect a component or trace may have failed under the stress of the RF oscillation.
Could you please help me with the next steps to diagnose this distorted signal?
Thanks!
Alberto
35,315
I assume that you mean TP502.
Instead, look at the B, C, E of Q504 and Q506.
We expect to find that Q506 and Q510 are not being driven correctly.
alprampo
Joined May 29, 2026
74
I will check the Base and Emitter. However, is it safe to connect the scope to the collectors, where I expect to find 60V? Will the scope survive that voltage?
Should I use a DMM to check the collectors instead?
Sorry for the beginner question, but as you can see, I am just starting to gain confidence with this wonderful instrument!
A note:
Q651 Q602 Q653 Q654 on power supply section, are HOT, more than usual.
Thanks
35,315
FNIRSI DSO152 oscilloscope is ok up to 40 V with a standard x1 probe. If you use a x10 probe, it is good to 400 V.
Yes, you can use the DMM to check the +60 and -60 V supplies on the collectors.
