Technics SU VX-800 with blown components (another one)
alprampo
Joined May 29, 2026
74
Well she still has too many volts on the signal path and this goes all the way from the Voltage Amp to the output transistors on the left channel. I leave it on the bench and try a thing or two every day! The layout of the SU-VX920 and SU-VX820 are very close to the SU-VX800, however the VX920 and VX820's use (rare and expensive) MOSFETs in the Class AA section in place of your Q427/Q428/Q429/Q430. I already sourced these once but since then I destroyed 4 output transistors unfortunately, so I hope they are still ok.
Have you also checked the front panel?
The SU-VX800 has a few parts that should have heatsinks but don't. Specifically, there are four 1W resistors on the front panel that run very hot, creating cold solder joints over time and making the PCB traces very fragile.
I also struggle with the PCB quality: I set my iron to 330°C, but if I remove a component just a couple of times, the pads lift right off. This is on top of the traces that were already degraded by the operational heat. As you might have read in my previous posts, some of the issues I encountered were actually due to the board flexing or moving; just a little bit of unintended pressure on a component was enough to break the pad on the copper side.
Thanks. I don't remember seeing those when I had the front off (many times!), so will look again. I hadn't thought about the flexing but that seems highly likely too. I've been very careful with desoldering, doing it quickly with flux and copper braid. I also am lucky that the board isn't black and burnt like many of this series. I already fitted extra heatsinks to the Active Servo transistor pair and the Class AA heatsink...but that's for when it works!
alprampo
Joined May 29, 2026
74
I checked the SM for the VX920: the front panel is actually quite different since it doesn't handle balanced inputs. It also uses the AN7062 IC, which could be responsible for the voltage offset at the output.
In any case, on my unit, the resistor issue I mentioned is located right behind the flat ribbon cable connector.
Also, if you need replacement power transistors, I have some spares available. I bought a large batch from Mouser to be absolutely sure they were genuine and to match their hFE as closely as possible since they are connected in parallel. I was just a few steps away from putting the back cover back on before this happened!
alprampo
Joined May 29, 2026
74
Hi all,
I hope you are doing well and that you aren't completely tired of me and my amplifier yet...
Unfortunately, due to a bit of bad handling, I'm pretty sad to report there has been no real progress since my last post—just new issues instead!
Here is the current situation:
  • Missing -17.8V Rail: The entire unit is dead now because I've lost the -17.8V rail, so nothing works anymore and it no longer enters "drive" mode. Almost all voltages across the board are completely off.
  • Component Checks:
    • Resistors R672, R674, R676, and R680 check out fine.
    • Q652 and Q654 test okay in-circuit.
    • On Q652, I measured -60V on the collector, but only a few millivolts on the Base and Emitter.
    • On Q651/Q653, I have +18V on their bases, but I am missing the +13.8V on pin 8 of IC651 (even though R663 is a 1 kΩ resistor and is properly connected), which seems very weird to me.
  • PCB Integrity: I inspected the board and couldn't find any other cracked traces besides the one I already repaired.
  • The Worst Part: I even had some smoke coming from the front panel area!
Any ideas on where to start troubleshooting this power supply/regulation collapse safely? Thanks in advance for bearing with me!
Oh not smoke as well! This amplifier just keeps on giving! Was the smoke from those large resistors in the front panel you mentioned earlier?
I'm not sure I can add much to help you locate this new problem, I had to take the Technics off the bench for a few days to fix a Yamaha power amp.
Is it somehow possible that the negative supply to this Active Servo has become uncoupled from the chassis ground to give weird voltages? If the components test ok but the numbers don't add up then is the IC651 faulty? I think many other op amp ICs can be stuck in here to test.
I can't quite follow the whole VX800 schematic layout without confusing it with the VX920 but this Active Servo area is a similar hot zone on the VX920 and tends to ruin the circuit boards there. At least the Active Servo area isn't affected by all the signal feedback circuits as I far as I can see.
Once I get the Yamaha buttoned up I'll get the Technics apart again to see what mood it is in tomorrow! They sure are a mystery and a nightmare.
35,327
If you need to work on the Technics VX920 (or any amplifier), we have to create a new thread for that otherwise it will get confusing.
Definitely was going to create a separate thread…..these amps are confusing enough without me making things worse! Would love to see this VX800 get going again.
alprampo
Joined May 29, 2026
74
Thanks @pumptronics for your help and wishes.
Smoke from the front panel could be not a real problem as it already happened on the same components, I interrupted power and put the finger to see if it was the same place and it was.
I'm worried about the missing 17.8 as I'm not understanding how it is possible.
@MrChips
I see you did no longer reply to my posts
Please don't feel under any pressure to reply—I know you've already spent a lot of time helping me (which I'm already incredibly grateful for!), and I don't want to be a nuisance. If you have the time and will to take a look with no hurry, your insight would be highly appreciated, but if you need to step away from this project, I completely understand.
Thanks again for everything!
Alberto
35,327
@MrChips
Alberto
No. I have not abandoned this repair project. Just know that there are two things at play here.
(1) Sometimes, life gets in the way and I don't have the spare time to look at this right now.
(2) When the situation gets complex, one needs to spend the time to analyze the problem carefully and plan a trouble shooting strategy.
In brief, when the magic smoke is released, it indicates that something is drawing too much current (the obvious thing).
If the supply voltage is low, it means that either something is loading down the power supply or the power supply is at fault (another obvious thing).
The trouble shooting strategy is to disconnect the load from the power supply in order to isolate the fault.
(I have yet to study the latest situation.)
alprampo
Joined May 29, 2026
74
Thank you so much, MrChips! Take all the time you need, I really appreciate your reassurance.
To help you analyze the puzzle when you have a moment, i'll post the exact chronological order of events and what led to the current state:
alprampo
Joined May 29, 2026
74
Thanks to your support, I managed to get the amp back to life! However, the previous power transistors (which came from AliExpress) weren't reliable, so I bought a batch of genuine Toshiba transistors from Mouser to ensure properly matched hfe pairs for parallel operation.
Here is how things went:
  • Left Channel Success: I started with the left channel, replacing the existing pair with a newly matched pair. It tested great, so I added the second pair to complete the set. Everything worked perfectly—high output power and clean sound just like before the initial damage.
  • Right Channel & Trace Failure: Moving to the right channel, the PCB trace leading to the Base of Q518 broke, and the sound immediately degraded.
  • Pad Repair & Front Panel Issues: I repaired the broken pad/trace, but then the front panel stopped working properly—some LEDs went out and the relays failed to engage. Curiously, wiggling Q654 brought the LEDs back briefly.
  • Power Supply Wire Short: Re-inspecting the power supply area, I found a jumper wire (previously used for a PCB trace repair) on the emitter of Q652 had disconnected and likely shorted something. Even though the circuit should theoretically work with just one pair installed, fixing that jumper left me with no signal output from the front panel.
  • Missing -17.8V Rail & Accidental Short: Checking front panel voltages revealed that the -17.8V rail was completely missing. While probing around, I accidentally shorted the +61V and -61V rails, which opened R602 and threw R603 completely out of spec.
  • Smoke from Front Panel: I replaced R602 and R603, but upon powering back up, smoke came from the front panel board—specifically in the area where I had previously replaced Q327, Q333, Q336, and their associated resistors. Those components got extremely hot again.
I haven't tested if Q327, Q333, and Q336 are completely fried yet.
No hurry.
Take your time to try to get the mess i did.
Pyrex
Joined Feb 16, 2022
580
Is the -61V available now?
If so , proceed step by step. Check the voltages and resistances with a multimeter, a deviation of +/- 10-15% is normal.
Check voltage on R678 ,15 Ohm,-60V on both pins. If no, replace R678 , put a 10-20 Ohm 1/4W resistor
Check voltage on R680, -60V and -50V on pins. Same on R674, as they are in parallel.If no,check resistance, both must have same resistance.
Check voltage R676 -50V and -38V on pins. Same on R672, as they are in parallel.If no, check resistance, both must have same value.
Check voltage on IC651, pin 4 , should read -14V , pin 8 14V.
Check voltage on R662 , 14V on both ends. Same on R664. If no, check resistance, both must have same values
When you power up, have you had any luck using the Dim Bulb Tester with this amp? Sorry, I can't remember if you were using one or not. I've been using a DBT with a variac and, whilst it hasn't always given predictable behaviour when troubleshooting, I think it has saved my DC Technics a few times. Once I thought it was fixed, I gave it full 240VAC. Then hours later I cycled the power off then on and it destroyed the output transistors anyway!
alprampo
Joined May 29, 2026
74
Hi Pyrex,
thanks for your reply
Yes, the+- 61V rails are back after replacing R602 and R603. However, the moment they came back, smoke started coming from behind the front panel most likely
I'm going to fix the damaged components on the front panel board first before taking any more measurements. I noticed that without the front panel connected, the low-voltage rails on the mainboard go completely out of control—for instance, the +- 7.8V feeding IC401 and IC402 shoot up to 25V or more!
I'll report back once the front panel is repaired and everything is hooked back up for proper testing.
alprampo
Joined May 29, 2026
74
No, the initial failure was actually external: the first accident happened when rain caused a short between the 220V AC mains line and the right-channel speaker cable lying on the floor while the amp was powered on, which instantly fried all the power transistors on that channel.
Everything after that was down to my own accidental shorts during troubleshooting!
  • First, I managed to destroy the left channel by accidentally shorting one of the power transistors.
  • Then, I shorted the probe wires coming from the bias test points, blowing another pair of outputs.
Since then, I've been running tests with only one pair per channel instead of two. I've also replaced numerous resistors, small-signal transistors, and at least one Zener diode.
So to be clear: none of the power transistors ever failed on their own—I took care of destroying them personally during testing!
and even now, with the low-voltage rails running out of control, the protection circuit is doing its job and staying active—the "Drive" LED is unlit, and the speaker relays are not engaging.
Fortunately, the power transistors are not involved or in danger this time!
alprampo
Joined May 29, 2026
74
I performed some replacements and cleaned up the broken pads in that area (double-checking the ones I had already repaired). I couldn't find any evidence of remaining shorts or broken traces. However, since there was smoke from the front panel earlier, I checked that area and found:
  • Q337 was dead and has been replaced.
  • I also replaced Q414 and IC651 on the mainboard.
After reconnecting everything, both rails are now present!
Here are my current measurements compared to expectations:
  • Main Supply Rails: Even though I'm getting +/-64V instead of 60V straight from the transformer, the regulated rail reads -17.6V, which I assume is well within tolerance.
  • R678: -64.4V / -63.3V
  • R680: Floating between -57.6V/-58V and -63.5V/-64V
  • R674: Same as R680
  • R676: -52V to -58V
  • R672: Same as R676
  • IC651: Pins read -13.1V and +13.2V, but they are unstable and oscillating between 13V and 13.4V. Also, the voltage isn't available immediately upon power-on; it slowly creeps up from 8V until it reaches those values.
  • R662 & R664: -17.4V to -17.6V
Remaining Issues:
  1. Protection Mode Trigger: After about 4 seconds, the amp goes into "Drive" mode for a brief moment, but then quickly drops back into protection mode (sometimes after 3 seconds, sometimes just 1).
  2. Abnormal Voltages on IC401 / IC402:
  • IC401: +4.5V / -10.7V
  • IC402: +7V / -8.5V
Just to add an important observation:
When I disconnect the cables coming from the front panel (CN302 A and B), the voltages go totally crazy—shooting up to around +60V and -25V (I don't remember the exact numbers, but they are extremely high compared to the designed values).
It really highlights how much the mainboard regulation depends on the front panel board being connected!
Alberto
alprampo
Joined May 29, 2026
74
Thanks, this is interesting for me...I might pop out this IC and try a new one.
You are definitely getting closer to working again!
Hi Pumptronics!
I'm not quite as optimistic as you yet... but I sure hope your prediction about the future comes true! :p I actually had the unit working in my hands and managed to ruin it again...:mad:
I installed a socket and replaced IC651, then tried putting the original one back in and found out it was actually still good.
Same with Q414—it tests fine on my component tester, though the longer pins on the new one definitely helped me repair the lifted/damaged PCB traces.
At this point, I'm pretty sure I have more than one issue going on—definitely at least one on the mainboard, because the voltage readings on pins 4 and 8 are different between IC401 and IC402, and I'm 100% sure they used to match even with the front panel disconnected.
Speaking of the front panel, IMHO it's not working properly either: on the scope, the signal coming from J222 and J224 floats around for a while and then disappears completely. So, for the moment, I'm leaving the front panel disconnected on my desk and grounding those lines instead. I've decided to essentially start from scratch, going back to Post #1 and following the 2018 troubleshooting thread between @Marius83 and @MrChips for the same unit
Quoting that post (https://forum.allaboutcircuits.com/threads/technics-su-vx800-amplifier.143789/post-1223622):
MrChips said:
I am just confirming what I suspected.J223 and J225 are labeled on the board as GND. Your measurements indicate that they are not connected to GND with CN302A disconnected.
Leave CN302A disconnected.
Connect:J222 J223 J224 J225 all together and connect to J401 (which we can be sure is our GND).
Now proceed with the voltage measurements. I am expecting to see new readings from what were previously reported.
So, I'm going to proceed very slowly from here with these baseline checks!
alprampo
Joined May 29, 2026
74
Hi all,
A small update: I'm starting to think the mainboard might actually be OK!
With the signal inputs and grounds tied together on J221-J224 to main ground, all the regulated voltages look good:
  • +7.6V and -7.3V on IC401 and IC402
  • +-13.6V on IC651
  • +-17.5V from the main regulation section
  • +- 64.5
Next, I'm going to repeat the test after reinstalling the missing Q428, Q430, and the power output transistors. If everything stays stable and normal with them back in place, I will definitely need your help troubleshooting the front panel!
Thanks!
alprampo
Joined May 29, 2026
74
Game over, gentlemen.
Before reinstalling the missing parts on the mainboard, I tested the amp with the front panel reconnected after replacing a few bad components on the front panel: D301, D302, and Q409.
I powered it up on the dim-bulb tester—the lamp looked fine at first, no "Drive" LED lit up, and then after a little while Q415 exploded. Right after that, all voltages vanished—even on the leads coming straight off the transformers—and the dim-bulb lamp wouldn't even light anymore.
I disconnected everything and started taking DMM readings on the transistors, and I spotted differences between the left and right channels on Q313 and Q314. They look like 2SK389 dual JFETs, which are virtually impossible to source reliably.
At this point, I don't think it's worth spending more than 100 euros given the risk of fakes and no guarantee that it will actually fix the unit.
after some time powering again without mainboard connected, dim bulb was on again, may be a sort of protection entered on transformers.
Thank you.
Alberto
