Technics SU VX-800 with blown components (another one)
alprampo
Joined May 29, 2026
8
Hi all,
I landed here while searching for help on repairing this unit. It was my first "good" amplifier, bought when I was young, now I'm 55. About a year ago, it stopped working due to an accident.
It was left powered on on a covered terrace, with the right speaker cable left disconnected from the speaker and lying the floor. When it started raining, both the speaker cable and the 230V plug ended up underwater. As a result, the right channel smoked and destroyed all the power transistors.
While taking some measurements to diagnose the issue and comparing them with the left channel, I accidentally caused a short, blowing up the left channel as well.
It took a while to discover the thread started by Marius83 for a very similar issue, where MrChips and JoeJester provided great help.
in the last months i readd it completely, but issue is not 100% equal.
I have since replaced a large number of components. The amp is no longer in protection mode, but it's still not working properly. During my last attempt, the left channel started playing—not immediately after powering on, but after I moved a power supply transistor (the PCB is damaged from heating and the copper trace is gone). However, shortly after, resistor R513 burned out.
At the time, I had all components installed but was testing with only one pair of power transistors per channel instead of four. Could the missing transistors have caused R513 to burn out?
Thanks in advance for the help!
Alberto
Pyrex
Joined Feb 16, 2022
534
Hi all,
Alberto
Circuit diagram needed
alprampo
Joined May 29, 2026
8
Thank you so much Pyrex for the reply!
Here is the service manual. I had to remove several pages due to the attachment size limit, but I can provide more if needed.
Below is a partial list of the components replaced during the first review (currently, I don't have access to the bench where the amplifier, notes, and spare parts are):
  • Output Transistors: All 2SA1265 and 2SC3182 (Most likely with fakes for the A1265, but no smoke yet)
  • Transistors:
    • Q420, Q422: 2SC3311A
    • Q430: 2SA1535A
    • Q418: 2SD1761
    • Q428: 2SC3944A
    • Q426: 2SA1123
    • Q424: 2SC2631
  • Diodes: D414, D416 (MA165)
  • Capacitors: C425, C426 (1 µF / 100 V - both exploded)
  • Resistors:
    • R446: 100 Ω
    • R509, R510, R512, R513: 680 Ω
    • R506 6.8 Ω
As soon as I can, I will also post photos of the damaged PCB.
Alberto
Pyrex
Joined Feb 16, 2022
534
I don't thing the missing pair of output xistors cause damage to the R513.
It's pretty strange that two capacitors C425/426 had exploded. They could only explode due to much higher voltage or because of incorrect polarity.
Since the device was affected by water, check all the transformers, you’d need a megohmmeter for that. Disconnect the secondary circuits from the transformers and measure the AC voltages; they should match those shown in the circuit diagram.
Some low-resistance resistors, not wire-wound, may show a good reading when measured, but when used with higher current, they can significantly increase their resistance.
And also keep in mind that these amplifiers are not easy to repair, because if you replace one bad component, and there are other damaged components left, when you power up the device, there will be smoke again.
For the start of the repair, limit yourself to fixing just one channel; once it works, you can compare the voltages and resistances with the readings of the other channel.
During repairs, connect the speakers through a resistor, about 50 ohms, because if there's DC voltage at the output, you could damage the speakers
alprampo
Joined May 29, 2026
8
Dear Pyrex,
Thanks for your suggestions.
Just to clarify, the amplifier itself did not get wet. Only the AC plug and the right channel speaker wires fell into the water while the unit was powered on and the speaker switch was set to A+B. The connected speaker is still working, as the main 220V circuit breaker tripped immediately.
I was confident that all damaged parts had been replaced. I checked every single transistor and resistor individually (it took an eternity) and replaced all the burnt components. I forgot to mention earlier that IC402 was actually cracked into two pieces, which I only discovered once I desoldered it.
I then tested the unit using a 50W halogen bulb in series with the AC line (halogen bulbs seem to be out of production now, so that's the only rating I had at home). The bulb behavior seemed fine, but there was no sound. However, after touching/reflowing Q651 and Q653, sound started playing on the left channel, but R513 immediately went up in smoke.
Since the issue doesn't appear to be related to the missing power transistors, I am going to re-check the PCB and replace the damaged resistor.
I've already read through the entire thread here:
https://forum.allaboutcircuits.com/threads/technics-su-vx800-amplifier.143789/
For reference, here is the link to the full high-resolution service manual:
https://drive.google.com/file/d/1tsiRmSXY-8_kohS8HKWzvBpnM8mMgfd7/view?usp=sharing
Any advice or suggestions on how to proceed would be greatly appreciated—such as whether I should remove key components to work on one channel at a time or perform specific isolation tests. I would really love to fix this myself!
Thanks,
Alberto
35,071
Just to let you know that I am following your thread. To be fair to other users, I am working on their amp repairs first and I will come back to your problem when I get the chance. In the meantime, I can give you some tips on how to proceed.
1) For now, refrain from removing components. Take clear, high resolution photos of both sides of the boards.
2) Disconnect all loudspeakers to avoid damaging them.
3) Build the AC lamp load circuit posted to avoid blowing two many components. Use plug and outlet that matches your 230 VAC EU style outlets.
alprampo
Joined May 29, 2026
8
Hi MrChips,
Thank you so much, I really appreciate your time and help!
Just for context, my Dim Bulb Tester setup is currently in the exact same state as yours, except for the power switch—I'm just using the switch on the power strip instead.
As anyone who knows these devices a bit is aware, Technics completely forgot to implement a heatsink for the medium-power transistors. On top of that, the mainboard on my unit is in very bad condition with several charred areas, making it probably one of the most beat-up amplifiers you could ever come across—though until the accident occurred, it was in full working order!
I'll follow your tips, take clear high-res photos of both sides of the boards, keep the speakers disconnected, and use the lamp limiter circuit before doing anything else.
Looking forward to your guidance whenever you have time.
Thanks again,
Alberto
Here a preview, better photos will come.
35,071
Sorry, I did not realize that this is the same beast that we wrestled with for three years starting in Dec 2017 with Marius83.
Hold off on the photos for now. Give us the symptoms.
1) Disconnect all loudspeakers.
2) Measure the voltages at the output (+) with respect to ground.
3) Measure the voltages at TP501 (+) and (-) and TP502 (+) and (-) with respect to ground.
4) Measure the supply voltages +60 V and -60 V with respect to ground if you know where to find them.
alprampo
Joined May 29, 2026
8
Good morning!
Greetings from Italy! Sorry for the delay, but I've spent all my available time rebuilding the damaged PCB pads and tracks. Now I should be ready to power it on and take some measurements.
A couple of quick questions before I start:
  1. I plan to power it up for the first time using the dim-bulb tester, then If nothing goes up in smoke, I'll remove the lamp and take proper measurements. Does that sound like a good plan?
  2. Is it safe to test with just a single pair of output transistors installed, or should I mount all of them right away?
Currently, the bias trimmers are turned fully counter-clockwise.
thanks!
Alberto
alprampo
Joined May 29, 2026
8
Hi Pyrex,
Thanks for the reply!
I replaced R513 with a 1/4 W resistor since that's all I had on hand. Electronics shops around here are very scarce and rarely carry what you need, so buying online is usually my only option. In Italy, we have access to the usual suppliers like DigiKey, RS, and Mouser, but as you probably know, they require a minimum order threshold, and shipping fees can be quite steep.
I tested both the 2SC3182 and 2SA1265, and they were indeed blown...
So I opened them up to inspect the die, and to my surprise, they actually look genuine—even though I bought them on AliExpress listed as "pulls" (removed from original gear).
If you think it's better to replace the 1/4 W resistor with 1 W before moving forward, I'll go ahead and place an order!
Thanks!
From left to right:
The 2SC3182N and 2SA1265N from AliExpress appear to have the same silicon die size as the original 2SA1265 pulled from the Technics unit.
The last one is from a different AliExpress seller who sold them as "used", but there are no signs of soldering on the leads, and all 5 pieces share the exact same production lot number...
Pyrex
Joined Feb 16, 2022
534
It's not necessary to use only the transistors that were mounted on the factory. Usually, local stores have suitable replacements.
A guy (on another forum ) struggled for a long time because he couldn't get easily the kind of transistors that were mounted in his amplifier. I wrote to him about how to find transistor replacements, he found them, and, even though it's strange since his qualifications weren't high, he managed to fix this amplifier.
So, briefly, you need to pay attention to whether it's a PNP or NPN transistor and what its manufacturing technology is.
Secondly , check Uce , Ic , Pd and hFE parameters. Check what the transitions frequency is.
Pick a transistor with roughly similar parameters to the original one. Check the substitute pinout , too.
There are other parameters too, but practically the ones mentioned above are enough for 90% of repairs.
Many differently marked transistors are actually the same transistors
35,071
Two transistors with the same marking do not have exact characteristics. A properly designed circuit will allow for variations in electrical properties.
As @Pyrex says, match Ge vs Si, NPN vs PNP, voltage, current, power, hFE, gain-bandwidth product, packaging, pinout.
alprampo
Joined May 29, 2026
8
I fully agree with both of you.
Once the amplifier is up and running again, upgrading to 2SC5200 and 2SA1943 will definitely be the best choice.
@MrChips, is it safe to check voltages at the test points with just a single pair of output transistors installed, or should all of them be mounted?
I've finished fixing the PCB and I'm ready to run the tests, but @Pyrex, as a reminder, R513 is currently a 1/4 W resistor.
Thanks for all the support!
Alberto
35,071
One of the goals is to get 0 V output with speakers not connected.
If the amplifier output stage consists of multiple transistors in parallel in order to achieve higher power outputs then yes, you can remove transistors and leave a single output pair.
Note that any audio tests at this stage should be done at low output levels.
