I am seeking assistance with an issue involving the F280039C MCU on a high-voltage PMSM (Permanent Magnet Synchronous Motor) drive system (>1000V). Here’s the problem:
- Setup:
- I use a LaunchPad F280039C kit to upload code to the inverter’s F280039C MCU via a standard JTAG interface.
- The code is developed in MATLAB/Simulink and flashed successfully in most cases.
- Issue Description:
- After uploading the code, the JTAG cable is disconnected, and the system is powered up (DC bus raised to rated voltage, followed by the MCU supply).
- Recently, two critical problems occurred:
- MCU Reset During Operation: When the JTAG cable is connected while the PMSM drive is running, the MCU resets and loses its code.
- LaunchPad Failure: After several attempts (with JTAG disconnected during operation), the code upload process failed entirely, and the LaunchPad kit appears to be damaged (possibly burned out).
- Key Observations:
- The issue arises only when interacting with the JTAG interface under operational conditions (high-voltage active).
- The LaunchPad kit worked fine initially but now seems non-functional after repeated attempts.
- Potential causes for the MCU reset/code loss during JTAG connection under operation?
- Recommendations to avoid damaging the debugger/programmer in high-voltage environments?
- Any isolation or grounding precautions specific to JTAG in such systems?
