TC4420 not working in LTSpice
ElectricSpidey
Joined Dec 2, 2017
3,350
I want to keep this real simple…I have the spice model from Microchip, I did the create symbol thing in LTSpice, the model is recognized but the sym is failing to run, I have already done all of the troubleshooting I could find online…so…
Two questions…
Is this a known issue?
Is there a known workaround/fix?
38,657
I haven't simulated that part, but double check that the symbol pinout matches the model file.
Post them both if you have a question.
ElectricSpidey
Joined Dec 2, 2017
3,350
I’m pretty sure the pin outs are correct, but I can’t be sure, and there are plenty of error messages, each one different depending on where I have the settings.
Here are the files if you want to have a look.
Note: I changed the .mod extension to .txt because the forum wouldn't let be upload a .mod.
eetech00
Joined Jun 8, 2013
4,721
Two questions…
Hi
Microchip models are known to have problems running in LTspice.
Most users give up trying to make them work.
If you post your .asc file, I'll make an attempt...
eT
