Maximum Input Rise and Fall times for TC4420 Mosfet Driver IC?
Papabravo
Joined Feb 24, 2006
22,116
To avoid the "slow switching" of the opto you can add a Schmitt trigger stage from the output of the opto to the input of the gate driver. I don't know if you can deal with the total delay time of the opto-Schmitt-gate driver and if you have tight margins for dead time in your application. I believe the opto is adding 3-5 μsec of delay from edge to change in output. Can you really tolerate that? You might have to consider some parts with a 40 nsec delay like the following HCPL 7710/0710 or similar devices.
AV02-0641EN (broadcom.com)
As a bonus the Schmitt Trigger stage would no longer be required.
ronsimpson
Joined Oct 7, 2019
4,894
The PC817 optocoupler is too slow. You should use a "digital" isolator.
There are isolated gate drivers with everything in one IC.
