Hi, using a pic16f18446 on a curiousity development board that has an onboard pickit (Pkob4). The board and chip is fine as my desktop pc uploads to it normally. Switched to a laptop running mplab v5.40 and i get this error when uploading
After pressing ok, im greeted with this error:
Calculating memory ranges for operation...
Erasing...
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x1f
program memory: start address = 0x660, end address = 0x7ff
configuration memory
Verify failed. [ Pgm ] at 0x0, expected 0x00003180, got 0x0000ffff
Programming did not complete.
How do i solve this issue?
p.s Low voltage programming is enabled and MCLRE is set.
Erasing...
