What is the preferred method of tacking down components in which one or more leads have had to be lifted from it's original pcb through hole ?
Physical stress consideration of original existing non lifted leads solder joints.
Preference to adhere component back down to PCB - where to apply the adhesive on the lifted component ?
Should you leave component lifted in the last soldering position or lay the component back down horizontally to the PCB ?
Preference in sealing compound or adhesive ( RTV, Epoxy, Plastic Bonding Epoxy, etc. )
Thanks for any suggestions.
