Jerry-Hat-Trick
- Joined Aug 31, 2022
- 865
I’d suggest, the first step is to check the full scale current of your meter by connecting a potentiometer, maybe 500 ohms in series with the meter and a 5V supply. The internal resistance of the meter coil itself will be small. This will give you the value of resistance you need in series with the meter recognizing that the PWM output from the transistor can be varied between 0 and around 4.7V with analogWrite(). Then, assuming you have two coils, each of which are firing 4 cylinders, I think that sniffing the negative terminal of one coil will give the same number of sparks as a 4 cylinder car per revolutionMovement on this is 120 degrees, 0-6k RPM. Same T2621 IC and clock spring movement.
If you only plan to build one unit I’d consider using strip board although a proper PCB is nice. It may be that the only code you’ll need to change is the linearization table, and an adjustment from 8000 to 6000 RPM
