Thanks For replyThe timers increment at the same speed the CPU runs. Typically, Fosc/4, so if you have a 20Mhz crystal, the cpu executes 4 millioni instructions per second, and timer0 with no pre-scaler increments at 4Mhz.
if timer0 increments same as CPU rans. how we measure the frequency lower than the CPU rans in Sync with Internal clocks in counter modesThe timers increment at the same speed the CPU runs. 4Mhz.
Thanks for replyUwe the capture part of the CCP module, See the datasheet, timer0 and runs in the background while other code is running.
Thanks for replyExternal clock, such as CLKOUT sync is to keep outside logic moving at the same speed as the CPU, or the fastest rate the CPU's pins could change state.
