Hello all.
I don't have a good background in electronics, but for certain purposes I am trying to understand the way disconnectors and circuit breakers work. So I came across the explanation given here: http://electrical-engineering-portal.com/disconnectors-load-switches-switch-disconnectors-cbs#3 which explains what circuit breakers and what disconnectors are and the difference between them.
In general, I get the difference: first open the CB, so the current is not flowing. Then you can open the disconnector. But with usage in context I am a bit more confused. I saw this part in switching between two rails: http://3.bp.blogspot.com/-je0x5PgZY.../g2LuPKUceKc/s1600/DoubleBusSingleBreaker.png . Let's consider only the utmost left part. We see 3 disconnectors and one circuit breaker (CB). If we want to switch the power line below from one rail to another, what would be the correct procedure? Open CB, open the disconnector on one rail, close the one on second rail and close the CB? Why is it okay then to completely disconnect the power line (with the CB) from either rail for a moment?
Otherwise, if we can just close the disconnector on rail two, and then open the one on rail one, I would assume that arcs would occur.
So, my questions are: (i) is the way this should work that I explain correct, and (ii) why is it okay to disconnect the power line below from either rail for a moment?
