Switching laser diode with BS170 MOSFET
Hendrik Bleus
Joined Feb 22, 2017
Hi folks,
Im trying to switch a laser diode on and off by using a square-wave signal with a max amplitude of 3.3V (can be lowered to match Vgs,thr). The max current throught the laser should be 350 mA, voltage over the diode is 4V. Is a Vcc of 5V enough or should it be higher? Which resistor values should I use? Can you guys help me to make this circuit?
datasheet BS170: https://www.farnell.com/datasheets/2304244.pdf
ericgibbs
Joined Jan 29, 2010
21,567
Hi Hendrik,
To drop a 5V to 4V [across the Laser] is 2.8R [~2.7R] @ 350mA.
The BS170 has a high on resistance of > 1.2R to 5R at 200mA.!
What are the details of the pulse drive signal.?
E
dl324
Joined Mar 30, 2015
18,454
The threshold voltage is the voltage at which the device just starts turning on. If you're going to be operating at 70% of the maximum rated current, you should be driving the gate hard enough to have a lower on resistance.
Is that the measured forward voltage? Or the maximum?
Just use Ohm's Law.
38,767
Many seem to completely misunderstand the Vgs(th) value of a MOSFET.
It's the value where the MOSFET just starts to turn on at a low Ids current (typically <1mA) so, to turn on the MOSFET as a switch with a low Rds(on), you want the applied Vgs to be well (several volts) above the max Vgs(th) value.
For an applied Vgs signal of 3.3V, you want a logic-level type MOSFET (max Vgs(th) < 2V) so it fully turns on.
