Switch relay?
BullMoose
Joined Nov 15, 2023
7
I need an on off switch to switch between 2 relays. For example, switch is off relay 1 has power , switch on relay 2 has power
BullMoose
Joined Nov 15, 2023
7
Wish i could. That would be easy. Customer is needing this specific switch do to specific looks for vintage application
Ya’akov
Joined Jan 27, 2019
10,263
You can wire the power for the second relay using the normally closed contact on the first relay. That way, when relay is off, relay 2 is on—and when relay one is turned on by the switch, it turns off relay 2.
Ya’akov
Joined Jan 27, 2019
10,263
The same way you wire a switch to operate the relay. Route power for relay 2 through the common and NC (Normally Closed). THe NC contacts are closed when there is no power to the relay and open when the relay is energized.
So the default for the switch is relay 2 on. That is, relay 2 will turn off when the switch is turned on and relay 1’s coil is energized.
But, be sure you recognize that no matter what scheme you use, relay 2 will constantly draw power unless you switch it off some other way (ignition, etc.).
