12v 3 way switch with SPDT relay
kresponde
Joined Apr 4, 2025
I am wiring up some 3 way switches in my camper van. I finally found a 12v switch that I can use in a real 3-day setup: https://www.amazon.com/dp/B09BKVTVF8/ref=cfb_at_prodpg?th=1
Wiring diagram that works exactly as I need it:
I'm running into an issue with one set of lights -- the switch will only handle 5 amps, and I have two 5 amp lights strung together. I want to add a 5-pin SPDT relay, but I can't figure out how to get it wired. Will this work for what I need?
If so, how do I wire it up?
28,411
The suggestion from LQC is what makes sense. Any other scheme can result in the relay being constantly powered, resulting in a constant hidden battery drain, which may be inconvenient.
28,411
YES!! Something exactly like that!! In industrial jargon that would be described as the switches as providing "pilot duty" for the power control relay.
