Switch on npn transistor not working (Simple circuit)
MrsssSu
Joined Sep 28, 2021
267
I recently bought KSP 2N2222a npn transistors. The picture that I attach below shows the layout. The base of the transistor is applied a 1.5V which turns on the transistors and light up the bulb very brightly. However, I got a bulb that is so dim. The battery power and voltage is fine because I tested it and the led light up so brightly. What did I go wrong here or the transistors are fake?
Thank you:)
ericgibbs
Joined Jan 29, 2010
21,637
hi Mrss,
You should not apply a 1.5V voltage directly to the Base
You must have a current limiting resistors, you most likely have blown the 2N2222.
E
