Surface Mount Chip
Discussion in 'General Electronics Chat' started by beatsal, Jan 7, 2019.
  1. beatsal
    Jan 21, 2018
    62
    I have a SMT chip TI Drv8881 which I am trying to connect to a board
    Pins are small .Best method to connect? hi Lise
  2. wayneh
    Sep 9, 2010
    15,206
    5,556
    Maybe you could use something like these? There are all sorts of options.
    absf, djsfantasi and MrSoftware like this.
  3. dl324
    Mar 30, 2015
    7,778
    1,858
    It would be helpful if you specified package type, what kind of board (custom PCB, strip board, pad per hole), and space available.
  4. jpanhalt
    Jan 18, 2008
    6,551
    1,300
    Use solder. That's what everyone else does.
    spinnaker likes this.
  5. spinnaker
    Oct 29, 2009
    7,264
    3,267
    I never got those things. You still need to solder! :( Maybe to make prototyping easier?
  6. MrSoftware
    Oct 29, 2013
    1,186
    348
  7. Norfindel
    Mar 6, 2008
    278
    15
    If you need to control a motor, there are some daugtherboards for motor control. Some of them could have that IC, or some other that controls the motor kind you have: https://www.pololu.com/category/9/motion-control-modules
    Will not have the same freedom than using the IC directly, but it's ready to use, if soldering SMT ICs is an issue.
  8. beatsal
    Jan 21, 2018
    62
    Thanks. It uses the smt ic chip from ti drv8881E which is a 28 pin chip. Ideally a breakout board for this chip but who supplies this?
  9. dl324
    Mar 30, 2015
    7,778
    1,858
    That part comes in two different SMT packages.
  10. kubeek
    Sep 20, 2005
    5,330
    1,005
    And both have thermal pads, for which you will need to use hot air to reflow the part properly. Not a good choice for someone who has little experience with smd.
    dl324 likes this.
  11. beatsal
    Jan 21, 2018
    62
    So wonder how to solve this.
  12. jpanhalt
    Jan 18, 2008
    6,551
    1,300
    Post #6 gives you a viable option. Why do you seem to reject that? Another option is to get or build the equipment needed and learn to solder it. Third, find another chip for your project that is not so challenging to solder.
    Let's start with why you picked that chip out of the plethora of motor control chips available? That is, what advantages attracted you to it? What are you using it for?
  13. kubeek
    Sep 20, 2005
    5,330
    1,005
    If you want to use this chip and do it right, you have to make a proper pcb and learn how to solder it. As jpanhalt suggests, if you are not absolutely stuck with this one, choosing a different chip would be the easiest option.
  14. beatsal
    Jan 21, 2018
    62
  15. beatsal
    Jan 21, 2018
    62
    Using the smaller of the 2 pkgs. Breakout board as suggested should work. Who supplies it?
  16. dl324
    Mar 30, 2015
    7,778
    1,858
    Why couldn't you just say you were using the WQFN package??
    You're going to need something like a reflow oven to solder the thermal pad. Do you have access to appropriate soldering equipment?
  17. beatsal
    Jan 21, 2018
    62
    Wayne suggested a breakout board. Looked at the links suggested here but could not find one for Drv 8881E
  18. beatsal
    Jan 21, 2018
    62
    No access
  19. dl324
    Mar 30, 2015
    7,778
    1,858
    You might try contacting a company that makes them https://schmartboard.com/smt-to-dip-adapters/
    They specialize in SMT to DIP adapters and they don't have one...
    Another option is to make your own.
  20. Norfindel
    Mar 6, 2008
    278
    15
    Or use an available board with a different IC. Why it does to be that one?
