Surface mount faucets box... do they exist ?
Externet
Joined Nov 29, 2005
2,676
Hi.
Wall is concrete, block or brick behind the laundry equipment. Pipes are surface mounted, not recessed in the wall. Does this box exist in not insertion type ? Have you ever seen one ? Most of the planet does not build hollow walls with studs and gypsum. What do they use for the task ?
