surface mount thermal switch?
joewales44
Joined Oct 8, 2017
218
i've been using a wired thermal switch but want to go surface mount.
i want it to cutoff at 60C regardless of current. also needs to withstand 40 volts.
72C is lowest temperature i've found. https://www.bourns.com/docs/Product-Datasheets/SC.pdf
what is arm terminal and base terminal? do i connect both arm terminals and current flows through to both base terminals?
will a thermistor do what i want? do they open or just go to high resistance?
thanks
