Summing op-amp works only as inverting?
StrongPenguin
Joined Jun 9, 2018
307
I'm trying to set up this circuit as a sum opamp, trying to get 8,3 V out, but not matter what I do, I get 9 V out. I tried setting both inputs to 3,3 V, which also resulted in 9 V out.
Does the summing opamp setup only work in the inverting input of the opamp?
ericgibbs
Joined Jan 29, 2010
21,460
hi PG,
That amp with a feedback and an input resistor of 10K, will give a Gain of one on the Inverting input.
ie: Gain =Rfb/Rin, G=10k/10k= 1,,, for the non inverting input the Gain is 1+ [Rfb/Rin] =2.
So I have added a resistive 10k divider on the non invert, as you have 10k input resistors.
So a 5Vin will appear as 2.5V at the NI input, the Gain of 2, will make the OPA Vout=5V
Same applies to the 3.3Vin.
I have assumed the output impedance of the 5V and 3.3V to be zero, in an actual circuit there will be some source resistance.
You may have to increase that 10k to 0v from the NI input to a higher value, I would use a 50k pot and adjust as required to to get correct Vout from the OPA.
Do you follow OK.?
E
Ylli
Joined Nov 13, 2015
1,092
For a true summing amplifier, you *need* to have the input look like a virtual ground. That means you need to use an inverting configuration. Take your original circuit and swap the inverting and non-inverting inputs. Then add an inverting stage with a gain of -1 on the output.
StrongPenguin
Joined Jun 9, 2018
307
I don't have a -12V supply, hence the non-inverting setup. When I made my computer PSU, I never thought I would need -12V for anything :rolleyes:
I will try that.
Ylli
Joined Nov 13, 2015
1,092
How accurate do you need it to be? This will be pretty close (the AD820 is probably not the best op amp. You want one with rail-rail inputs, designed for single supply)Capture.JPG
ericgibbs
Joined Jan 29, 2010
21,460
hi SP,
What is the purpose of combining the 5v & 3.3v to give 8.3v.?
They maybe alternative ways of getting the required result.
E
