Hello everyone,
I am trying to implement an op-amp that will subtract two voltages using this topology.
The thing is when the correct output voltage tends to be less than one volt, I cant get the correct result unless I use another power supply so I can give to the op-amp (741) negative supply voltage.
So, can I take correct result with only one positive DC supply voltage? Thanx in advance.
