Suitable circuit for switching a reversing polarity signal
orbitcoms
Joined Apr 6, 2017
I have an H-Bridge circuit that currently uses physical switched to select the load across the bridge (as attached)
I want to change the switching from physical dip switch to digital. Relays are not feasible because the loads are switched several times a second continuously and will wear out the contacts. The frequency is 125 kHz
It seems SSR will only be useful for switching 240VAC.
Is there a small SMD device that would do want I want? Alternately, owuld something like my circuit "Switched" do the trick?
38,909
Well, 125 kHz is certainly several times a second (125,000 times per second to be exact), which is way beyond anything a mechanical relay could do.
Is that really how fast you need to switch?
dendad
Joined Feb 20, 2016
4,642
A lot depends on what it is you are actually switching.
Like, the signals source,
Signal level,
Load,
More details please.
What are you actually trying to do?
