Suggestion for an alternative operational amplifier
somaye2022
Joined Mar 23, 2022
100
Hi everyone, I need to use an alternative Opamp (TLV342AIDR) as a dark signal replacement for AD8692ARZ for an image sensor board after DAC and I need a 100nF capacitive load allowance for this Opmap, I could not find a distinct outcome about maximum capacitive load allowance in either of the datasheets. Could you please help me in that regard?
Thank you very much in advance
Best regards
Somayeh
38,784
In general, you will need some added circuitry on the output (possibly just a resistor depending upon your signal requirements).
Here's an Analog Devices' discussion of that.
somaye2022
Joined Mar 23, 2022
100
Thank you for your reply,
However, the problrm is that the opamp AD8692ARZ works so far with no problems or extra circuitry, and I just need to replace that opamp with another one that is no longer available with (pin copatible OP) for example TLV342AIDR without changing the layout.
somaye2022
Joined Mar 23, 2022
100
Most op-amps will oscillate if a capacitive load is connected.
This paper tells you how to connect a capacitive load without it oscillation
https://www.analog.com/media/en/ana...s-to-avoid-instability-capacitive-loading.pdf
Don’t be fooled into thinking that slow op-amps like the LM324 won’t have a problem. They are the worst.
Ian0
Joined Aug 7, 2020
13,267
I suggest you follow the advice of the good people from Analog Devices.
No op-amp is guaranteed stable into 100nF.
If you want to continue to push your luck, that’s your choice.
somaye2022
Joined Mar 23, 2022
100
I underestand what do you mean, but Im am not a Boss, im not allowed to change the layout. Hier is my task attached!20220425_181439.jpg
Ian0
Joined Aug 7, 2020
13,267
It doesn’t have a capacitive load. There’s 2.2k in series.
That’s a low pass filter at 723Hz, so I’m wondering why anyone specified a 10MHz bandwidth op-amp.
Any old op-amp will do the job, and there won’t be much noise in 723Hz bandwidth.
How important is offset voltage? And rail-to-rail inputs and outputs?
The capacitive load business is irrelevant.
somaye2022
Joined Mar 23, 2022
100
exactly,, I also have the same thinking, I dot Konw why they talk to me about capacitive load capability.
And about offset voltage is so important here. But rail to rail input and output not necessarily!
Ian0
Joined Aug 7, 2020
13,267
There doesn't seem to be such a thing as LTC6664. If it did exist, and if it had a lot of input bias current the resistor would cause an offset problem.
somaye2022
Joined Mar 23, 2022
100
you are right. The AD-driver is LTC6404IUD, and the input current of that is 28mA, is that ok?
somaye2022
Joined Mar 23, 2022
100
Thank you very much for all helps from you!
I discussed with my boss that unfortunately there is no 2.2K resistor, there is a 1 ohm protective resistor. That was my mistake while reading from Altium.
Therefore, there is always the problem of load capability of 100nF.
Kind thanks in advance
Somayeh
somaye2022
Joined Mar 23, 2022
100
So, what bandwidth do you need?
What is the ADC's sample frequency?
Thank you for your reply.
To be honest with you, I don't know, but the ADC is LTC2203 and the ADC driver before that is LTC6404IUD-1.
They don't give me too much info, they told me Opamp number AD8692ARZ could do this job with 100nF. Now I muss tell them, if Opamp with Mf.p.n TLV342AIDR could do the same job. I have compared already two Opamps, everything except load capability to replace of the camera Board is fine.
