Sorry, I don't have time to watch videos.
In order to design what you call your servo amplifier, you have to accurately understand the other components of the loop gain. If the servo amplifier is like you have drawn it then you have a Type 2 PLL. There are two integrators in the loop, one is the VCO and the second is the integrator in the servo amplifier. The loop gain is (ideally) infinite at DC and drops at 40dB/decade. You need to figure out where it would be unity so you can place the zero in your servo amplifier to ensure you have adequate phase margin. If you are having trouble with stability then I would suspect that either you don't have sufficient phase margin (probably as your loop gain calculation is incorrect), or the external drift (the tendency of the YIG to change frequency due to say temperature) is too fast for you loop to track. In this case you need to increase the loop bandwidth or reduce the drift.
With no external stimulus the error signal should be zero when the loop is locked, if it non-zero then the loop is tracking a consistent frequency drift. Sounds like you need to understand your YIG stability and the ability of the PLL to track it. If you hold the frequency control line to the YIG constant what happens to the frequency? Is your PLL designed to track it? This is a fairly straightforward control system question you should answer.
