drjohsmith
- Joined Dec 13, 2021
- 1,662
Also
Check the threshold voltage the inverter needs for a 0 and a 1.
You mention 10 volts , that's a fair skew rate needed , wonder how long the 555 takes to get to a 1 level on it's output ..
Also check when those output fets turn on , depending what's on the output connectors , there is likely to be a big dip in the power rail to the 555 and the inverters , which could cause spurious logic.
E.g. A long wire or inductive load on those fets could be a problem .
The led resistor also looks a bit high .
And check the on / off voltage of the fets with the resistance in their legs.
