Strange MOSFET operation
Vorador
Joined Oct 5, 2012
87
It's the first time I'm using a MOSFET. It's called IR540 and is apparently an Enhancement-mode N-channel MOSFET.
I made a simple a circuit to test its switching operation. I am using a 9V battery. I connect a 10k resistor between Vdd and the drain of the FET and ground the source. It starts conducting after I connect Vdd to the gate but it continues conducting even after I remove Vdd from it.
I tried using another FET of the same model, but that one behaves even more strange. It works without any gate voltage at all from the get go.
I have rechecked the which terminals are which several times and I don't think I'm making a mistake there.
I'm working with the assumption that with the front of FET facing me, the leftmost pin is G, middle D and rightmost S. I don't think I'm wrong there.
Any ideas?
DickCappels
Joined Aug 21, 2008
10,661
MOSFETs are controlled by voltage. There is considerable capacitance between the gate and the other electrodes, and there is some leakage. When you touched the gate to the drain voltage you charged up the gate capacitance, and unless you dump the charge, such as by connecting the gate to the source directly or through a resistor or other component, the gate will stay charged for a long time.
Depending upon the leakage current, if you don't discharge the gate capacitance it might never discharge or do so slowly.
Strange, the IR datasheet does not give the pin assignments. I think your assignment is correct, but I like to see it in the datasheet just in case.
Hypatia's Protege
Joined Mar 1, 2015
3,228
I made a simple a circuit to test its switching operation. I am using a 9V battery. I connect a 10k resistor between Vdd and the drain of the FET and ground the source. It starts conducting after I connect Vdd to the gate but it continues conducting even after I remove Vdd from it...
Congratulations! you have a working MOSFET! :D
OBW0549
Joined Mar 2, 2015
3,565
That is perfectly normal. Once you placed a positive charge on the gate by connecting it to +9V, disconnecting the +9V simply left the charge on there. With nothing to drain off the charge (like a resistor between gate and source), the gate stayed positively biased and kept the MOSFET on.
38,838
You made the common newbie mistake of thinking an open input is at zero potential.
For high impedance devices, such as CMOS logic circuits and other MOSFETs, an open gate input is floating, and can be at any potential.
Vorador
Joined Oct 5, 2012
87
Hehe. It is funny because I have previously corrected my friends for making the same mistake that I have made here.
Thanks a lot everyone! Makes perfect sense now.
Though, just to be sure, I have to ask: I want to use MOSFET in a switching circuit triggered by pulses. Would the MOSFET turn off when the gate pulse reaches 0V without there being a resistor between gate and source? I'm pretty sure it would, but just want to be sure.
Final question: What happens if Vgs goes negative in an n-channel E-MOSFET? Does it remain off?
Thanks again, people!
LOL! :D
#12
You know a mosfet is a complete cripple when it comes to controlling its own gate. The answer depends entirely on the driver. An open collector comparator? Must have a pull-up resistor. A Class A amplifier? Must have a load. An op-amp? Usually has a bipolar driver that sources and sinks current.
OBW0549
Joined Mar 2, 2015
3,565
Sure. The important thing is that whatever drives the MOSFET gate must drive it to the desired voltage; simply making it open-circuit is a no-no.
Yes, it remains off. What else it does depends on the MOSFET, and what kind of gate protection is built into it: some have a gate-to-source Zener diode to protect the gate from electrostatic discharge, and will not tolerate a negative drive voltage on the gate. Always consult the MOSFET data sheet to see what the gate drive requirements and restrictions are.
dl324
Joined Mar 30, 2015
18,474
With sufficiently high Vds, there will be some drain current flowing with Vgs=0V. Making Vgs negative will increase channel resistance and decrease leakage current; but you can't exceed the max specified in the datasheet.
