Strange error when programming PIC for BMP280
jjw
Joined Dec 24, 2013
823
Clip from Manual:
.HW,.LW,.3B,.4B,
High word (composed by bytes 3 and 2) and low word (composed by bytes 1 and 0) of a Long (Single) variable can be addressed by .HW and .LW extensions. Byte 0 can be addressed by .LB and byte 1 by .HB extensions. The third and the fourth byte of Long and Single variables can be addressed by .3B and .4B extensions. Individual bits can be addressed by .0, .1, ..., .3
A Long (Single) variable can be addressed by .HW and .LW
Clip end.
The .HW can be accessed by .HB and .LB or .3B and .2B
The .LW can be accessed by .HB and .LB or .1B and .0B
So a LONG variable can be seen as
.HW [ .HB & .LB] + .LW[ .HB & .LB] or .3B .2B .1B .0B
Example:
Dim along as LONG
Dim hword as WORD
Dim lword as WORD
Dim hbyte as BYTE
Dim lbyte as BYTE
Set:
along= 0x12345678
hword =0x1234
lword = 0x5678
hbyte of hword = 0x12
lbyte of hword = 0x34
hbyte of lword = 0x56
lbyte of lword = 0x78
So this is the location of the BYTE
hword = 0x1234
lword = 0x5678
.3B = 0x12
.2B = 0x34
.1B = 0x56
.0B = 0x78
Your post says: Pressure MSB, in the PIC D/S it uses HB LB and 3B,
How can that be correct.?
E
Study the above breakdown so that you understand the 'weighting' location of the bytes in LONG add WORD
I did not find .1B and .0B in the manual ( web site), but .3B, .HB , .LB work in a long variable.
There is an example where a byte is read from a long using .LB
camerart
Joined Feb 25, 2013
3,842
You have ( had ) these right in the old working program.
For example the pressure:
Dim p_raw as long
p_raw.3B = periph_rd(0xF9)
p_raw.HB = periph_rd(0xF8)
p_raw.LB = periph_rd(0xF7)
Hi J,
Yes, I used these to start with, but the result was wrong. We will go through it all again this afternoon. (Some of the variables have changed name)
C
camerart
Joined Feb 25, 2013
3,842
From an earlier suggestion READ ALTMTR registers is done with this [ p_raw.LB = periph_rd_alt(0xf7) ]
The best we have achieved so far is with this CODE, that uses an older READ method, copied from a working TP and PR good program:
The attached CODE gives consistent, but incorrect READings, where if I warm the sensor up, the TP number goes down.
NOTE: the ALT SHOW line in the JPG, may not be worded correctly!
NOTE: The D/S says to use Burst mode READ which could be the problem?
C
Code:
''READ ALTMTR BMP280
'Proc read_altmtr()
''READ three bytes of pressure:'DAVE's
'altmtr_cs = 0
'p_raw.3B = periph_rd_alt(0xf9)
'altmtr_cs = 1
'altmtr_cs = 0
'p_raw.HB = periph_rd_alt(0xf8)
'altmtr_cs = 1
'altmtr_cs = 0
'p_raw.LB = periph_rd_alt(0xf7)
'altmtr_cs = 1
'altmtr_cs = 0
'p_raw = ShiftRight(p_raw, 4)
'altmtr_cs = 1
'adc_p = p_raw
''READ three bytes of temperature:
'altmtr_cs = 0
't_raw.3B = periph_rd_alt(0xfc)
'altmtr_cs = 1
'altmtr_cs = 0
't_raw.HB = periph_rd_alt(0xfb)
'altmtr_cs = 1
'altmtr_cs = 0
't_raw.LB = periph_rd_alt(0xfa)
'altmtr_cs = 1
't_raw = ShiftRight(t_raw, 4)
'adc_t = t_raw
    Toggle rled  '[yled]
    't_raw.LB = b(2)  'Altimeter TEMPERATURE  [[[ PREVIOUS VALUES  ]]]
    't_raw.HB = b(1)  'Altimeter
    't_raw.3B = b(0)  'Altimeter
    'adc_t = t_raw
    'p_raw.LB = b(2)  'ba Altimeter Pressure
    'p_raw.HB = b(1)  'ba Altimeter
    'p_raw.3B = b(0)  'ba Altimeter
    'adc_p = p_raw
'###########ADDED#######################
Proc read_altmtr()
altmtr_cs = 1  'ADDED!!!!!!!!!!!!!!!
    For i = 0 To 2  'Altimeter TEMPERATURE
    Toggle rled
        altmtr_cs = 0  'CHIP SELECT BMP280 ON
        rd_adr = 0xfa + i  '7A=WRITE FA=READ Altimeter
        WaitUs 1
        SSPBUF = rd_adr
        While Not SSPSTAT.BF
        Wend
        WaitUs 1
        SSPBUF = 0  'Dummy BYTE
        Wend
        periph_rd = SSPBUF
        b(i) = periph_rd  'data  'Altimeter
        altmtr_cs = 1  'CHIP SELECT BMP280 OFF
    Next i  'ia altimeter
    adc_t = t_raw
        rd_adr = 0xf7 + i  '00=WRITE 80=READ Altimeter
        WaitUs 1
        SSPBUF = rd_adr
        Wend
        WaitUs 1
        Wend
        periph_rd = SSPBUF
    p_raw.LB = b(2)  'ba Altimeter TEMPERATURE
    adc_p = p_raw
Call calca()  'ALTMTR BMP280
    strtp = #tp
    strpr = #pr
End Proc
'@@@@@@@@@@@@@@@@FROM 190921 1001 TP PR CORRECT @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
'read_BMP280:
    'SPICSOn
    'For i = 0 To 2  'Altimeter TEMPERATURE
        'altmtr_cs = 0  'CHIP SELECT BMP280 ON
        'adr = 0xfa + i  '00=WRITE 80=READ Altimeter
        'SPISend adr
        'SPIReceive data  'dataa Altimeter
        'b(i) = data  'Altimeter
        'altmtr_cs = 1  'CHIP SELECT BMP280 OFF
    'Next i  'ia altimeter
    'adc_t = t_raw
    'For i = 0 To 2  'Altimeter PRESSURE
        'adr = 0xf7 + i  '00=WRITE 80=READ altimeter
        'SPISend adr
        'SPIReceive data  'altimeter
        'Next i  'Altimeter
    'SPICSOff
    'p_raw.LB = b(2)  'ba Altimeter TEMPERATURE
    'adc_p = p_raw
    'Gosub calca
    'strtp = #tp
    'strpr = #pr
'Return
'###########ADDED########################
'Call calca()  'ALTMTR BMP280
    'strtp = #tp
    'strpr = #pr
'End Proc
jjw
Joined Dec 24, 2013
823
C
Code:
'Proc read_altmtr()
'altmtr_cs = 0
'altmtr_cs = 1
'altmtr_cs = 0
'altmtr_cs = 1
'altmtr_cs = 0
'altmtr_cs = 1
'altmtr_cs = 0
'altmtr_cs = 1
'adc_p = p_raw
'altmtr_cs = 0
'altmtr_cs = 1
'altmtr_cs = 0
'altmtr_cs = 1
'altmtr_cs = 0
'altmtr_cs = 1
'adc_t = t_raw
    Toggle rled  '[yled]
    'adc_t = t_raw
    'adc_p = p_raw
Proc read_altmtr()
    Toggle rled
        WaitUs 1
        SSPBUF = rd_adr
        Wend
        WaitUs 1
        Wend
        periph_rd = SSPBUF
    adc_t = t_raw
        WaitUs 1
        SSPBUF = rd_adr
        Wend
        WaitUs 1
        Wend
        periph_rd = SSPBUF
    adc_p = p_raw
    strtp = #tp
    strpr = #pr
End Proc
'read_BMP280:
    'SPICSOn
        'SPISend adr
    'adc_t = t_raw
        'SPISend adr
        'Next i  'Altimeter
    'SPICSOff
    'adc_p = p_raw
    'Gosub calca
    'strtp = #tp
    'strpr = #pr
'Return
    'strtp = #tp
    'strpr = #pr
'End Proc
The old program did not use the burst mode and worked, so it is not reason.
Show the calca and the trimming parameters.
This has an extra step:
periph_rd = SSPBUF
b(i) = periph_rd
Replace with b(I)=SSPBUF
camerart
Joined Feb 25, 2013
3,842
Am I correct that both XLSB BYTEs contain a fixed setting, so should be 1,2,4,8 or 16 and not change?
C
camerart
Joined Feb 25, 2013
3,842
periph_rd = SSPBUF
b(i) = periph_rd
Hi J,
Is this correct: Replace with b(I)=SSPBUF ?
C
camerart
Joined Feb 25, 2013
3,842
b( i ) of course.
Hi J,
Good! I use more read and write than copy and paste as i used to, so you've improved my habits:)
C.
COMP PAR:
Comp PAR =216
Comp PAR =167
Comp PAR =50
Comp PAR =116
Comp PAR =171
Comp PAR =208
Comp PAR =46
Comp PAR =207
Comp PAR =249
Comp PAR =140
Comp PAR =248
Comp PAR =112
Comp PAR =0
Comp PAR =55
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =51
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =96
Code:
'ALTITUDE TEMP CALC
Proc calca()  'ALTMTR BMP280
    'Calculate temperature
    var1 = ((adc_t / 16384 - (dig_t1 / 1024))) * dig_t2
    var2 = (((adc_t) / 131072 - (dig_t1) / 8192) * (adc_t / 131072 - dig_t1 / 8192) * dig_t3)
    t_fine = var1 + var2
    tp = (var1 + var2) / 5120
    'Calculate pressure
    var1 = t_fine / 2 - 64000
    var2 = var1 * var1 * dig_p6 / 32768
    var2 = var2 + var1 * dig_p5 * 2
    var2 = var2 / 4 + dig_p4 * 65536
    var1 = ((dig_p3) * var1 * var1 / 524288 + dig_p2 * var1) / 524288
    var1 = (1 + var1 / 32768) * dig_p1
    pr = 1048576 - adc_p
    pr = (pr - (var2 / 4096)) * 6250 / var1
    var1 = dig_p9 * pr * pr / 2147483648
    var2 = pr * dig_p8 / 32768
    pr = pr + (var1 + var2 + dig_p7) / 16
End Proc
jjw
Joined Dec 24, 2013
823
Hi J,
C.
COMP PAR:
Comp PAR =216
Comp PAR =167
Comp PAR =50
Comp PAR =116
Comp PAR =171
Comp PAR =208
Comp PAR =46
Comp PAR =207
Comp PAR =249
Comp PAR =140
Comp PAR =248
Comp PAR =112
Comp PAR =0
Comp PAR =55
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =51
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =96
Code:
'ALTITUDE TEMP CALC
    'Calculate pressure
End Proc
I mean the single values dig_ti etc.
camerart
Joined Feb 25, 2013
3,842
Hi J,
Here they are:
C
Code:
Proc init_altmtr_comppar()  'READ and SET Compensation parameters
        For i = 0 To 23
        rd_adr = 0x88 + i  '00=WRITE 80=READ
        WaitUs 1
        SSPBUF = rd_adr
        Wend
        WaitUs 1
        Wend
        periph_rd_alt = SSPBUF
        b(i) = periph_rd_alt
    Next i
'Temp coefficents
    t1.LB = b(0)
    t1.HB = b(1)
    t2.LB = b(2)
    t2.HB = b(3)
    t3.LB = b(4)
    t3.HB = b(5)
'pressure coefficients
    p1.LB = b(6)
    p1.HB = b(7)
    p2.LB = b(8)
    p2.HB = b(9)
    p3.LB = b(10)
    p3.HB = b(11)
    p4.LB = b(12)
    p4.HB = b(13)
    p5.LB = b(14)
    p5.HB = b(15)
    p6.LB = b(16)
    p6.HB = b(17)
    p7.LB = b(18)
    p7.HB = b(19)
    p8.LB = b(20)
    p8.HB = b(21)
    p9.LB = b(22)
    p9.HB = b(23)
'convert to singles with sign
    dig_t1 = t1
    dig_t2 = t2
    If dig_t2 > 32767 Then
        dig_t2 = dig_t2 - 65536
    Endif
    dig_t3 = t3
    If dig_t3 > 32767 Then
        dig_t3 = dig_t3 - 65536
    Endif
    dig_p1 = p1
    dig_p2 = p2
    If dig_p2 > 32767 Then
        dig_p2 = dig_p2 - 65536
    Endif
    dig_p3 = p3
    If dig_p3 > 32767 Then
        dig_p3 = dig_p3 - 65536
    Endif
    dig_p4 = p4
    If dig_p4 > 32767 Then
        dig_p4 = dig_p4 - 65536
    Endif
    dig_p5 = p5
    If dig_p5 > 32767 Then
        dig_p5 = dig_p5 - 65536
    Endif
    dig_p6 = p6
    If dig_p6 > 32767 Then
        dig_p6 = dig_p6 - 65536
    Endif
    dig_p7 = p7
    If dig_p7 > 32767 Then
        dig_p7 = dig_p7 - 65536
    Endif
    dig_p8 = p8
    If dig_p8 > 32767 Then
        dig_p8 = dig_p8 - 65536
    Endif
    dig_p9 = p9
        If dig_p9 > 32767 Then
    dig_p9 = dig_p9 - 65536
    Endif
End Proc
camerart
Joined Feb 25, 2013
3,842
Hi J,
I hoping for Burst READ eventually. Since burst READing the Compass, the output is much more stable, as previously I had a 250 averaging routine to smooth it, and now it is within a couple of degrees.
C
jjw
Joined Dec 24, 2013
823
Hi J,
Here they are:
C
Code:
        For i = 0 To 23
        WaitUs 1
        SSPBUF = rd_adr
        Wend
        WaitUs 1
        Wend
    Next i
'Temp coefficents
    t1.LB = b(0)
    t1.HB = b(1)
    t2.LB = b(2)
    t2.HB = b(3)
    t3.LB = b(4)
    t3.HB = b(5)
    p1.LB = b(6)
    p1.HB = b(7)
    p2.LB = b(8)
    p2.HB = b(9)
    p3.LB = b(10)
    p3.HB = b(11)
    p4.LB = b(12)
    p4.HB = b(13)
    p5.LB = b(14)
    p5.HB = b(15)
    p6.LB = b(16)
    p6.HB = b(17)
    p7.LB = b(18)
    p7.HB = b(19)
    p8.LB = b(20)
    p8.HB = b(21)
    p9.LB = b(22)
    p9.HB = b(23)
    dig_t1 = t1
    dig_t2 = t2
    Endif
    dig_t3 = t3
    Endif
    dig_p1 = p1
    dig_p2 = p2
    Endif
    dig_p3 = p3
    Endif
    dig_p4 = p4
    Endif
    dig_p5 = p5
    Endif
    dig_p6 = p6
    Endif
    dig_p7 = p7
    Endif
    dig_p8 = p8
    Endif
    dig_p9 = p9
    Endif
End Proc
Hi J,
Here they are:
C
Code:
        For i = 0 To 23
        WaitUs 1
        SSPBUF = rd_adr
        Wend
        WaitUs 1
        Wend
    Next i
'Temp coefficents
    t1.LB = b(0)
    t1.HB = b(1)
    t2.LB = b(2)
    t2.HB = b(3)
    t3.LB = b(4)
    t3.HB = b(5)
    p1.LB = b(6)
    p1.HB = b(7)
    p2.LB = b(8)
    p2.HB = b(9)
    p3.LB = b(10)
    p3.HB = b(11)
    p4.LB = b(12)
    p4.HB = b(13)
    p5.LB = b(14)
    p5.HB = b(15)
    p6.LB = b(16)
    p6.HB = b(17)
    p7.LB = b(18)
    p7.HB = b(19)
    p8.LB = b(20)
    p8.HB = b(21)
    p9.LB = b(22)
    p9.HB = b(23)
    dig_t1 = t1
    dig_t2 = t2
    Endif
    dig_t3 = t3
    Endif
    dig_p1 = p1
    dig_p2 = p2
    Endif
    dig_p3 = p3
    Endif
    dig_p4 = p4
    Endif
    dig_p5 = p5
    Endif
    dig_p6 = p6
    Endif
    dig_p7 = p7
    Endif
    dig_p8 = p8
    Endif
    dig_p9 = p9
    Endif
End Proc
Could you print them and the raw values of t and p.
I would then calculate the temperature and pressure.
camerart
Joined Feb 25, 2013
3,842
Hi J,
Can you clarify 'them' in your sentence please.
EDIT: The DIG values are calculated each time using the [ convert to singles with sign ] section of the CODE in #32
The RAW values are in the link #24 shows them in ALT SHOW. e,g, P_MSB = P_RAW.3B
C.
jjw
Joined Dec 24, 2013
823
Hi J,
C.
You must have the values of dig_t1... dig_p1...
and t_raw, p_raw, when you calculate the temperature and pressure.
Print the actual values .
I don't want to dig bytes from #29 ( param= ...) or .3B .HB .LB
camerart
Joined Feb 25, 2013
3,842
Hi J,
Is this it?
C
Code:
READY
ALT SHOW  ID 0x58 88  =88  CTRL_MEAS B7 or 183 =183  CONFIG 0x10 or 16  =16
T1  =42968
T2  =29746
T3  =53419
P1  =53038
P2  =36089
P3  =28920
P4  =14080
P5  =0
P6  =0
P7  =51
P8  =0
P9  =24576
DIG_T1  =42968.00
DIG_T2  =29746.00
DIG_T3  =-12117.00
DIG_P1  =53038.00
DIG_P2  =-29447.00
DIG_P3  =28920.00
DIG_p4  =14080.00
DIG_P5  =0.00
DIG_P6  =0.00
DIG_P7  =51.00
DIG_P8  =0.00
DIG_P9  =24576.00
Comp PAR =216
Comp PAR =167
Comp PAR =50
Comp PAR =116
Comp PAR =171
Comp PAR =208
Comp PAR =46
Comp PAR =207
Comp PAR =249
Comp PAR =140
Comp PAR =248
Comp PAR =112
Comp PAR =0
Comp PAR =55
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =51
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =96
ALT SHOW P_MSB =15 - P_LSB =255 - P_XLSB =255 - T_MSB =15 - T_LSB =255 - T_XLSB =255
TP=  110.08  PR=  -33244.80
COMPASS SHOW  72   153   1   51   0   77   0   113   1   16
COMP DEG  283.94
COMPASS SHOW  72   153   1   55   0   83   0   111   1   16
COMP DEG  286.81
COMPASS SHOW  72   153   1   57   0   87   0   107   1   16
COMP DEG  288.72
jjw
Joined Dec 24, 2013
823
X
Hi J,
Is this it?
C
Code:
READY
T1  =42968
T2  =29746
T3  =53419
P1  =53038
P2  =36089
P3  =28920
P4  =14080
P5  =0
P6  =0
P7  =51
P8  =0
P9  =24576
DIG_T1  =42968.00
DIG_T2  =29746.00
DIG_T3  =-12117.00
DIG_P1  =53038.00
DIG_P2  =-29447.00
DIG_P3  =28920.00
DIG_p4  =14080.00
DIG_P5  =0.00
DIG_P6  =0.00
DIG_P7  =51.00
DIG_P8  =0.00
DIG_P9  =24576.00
Comp PAR =216
Comp PAR =167
Comp PAR =50
Comp PAR =116
Comp PAR =171
Comp PAR =208
Comp PAR =46
Comp PAR =207
Comp PAR =249
Comp PAR =140
Comp PAR =248
Comp PAR =112
Comp PAR =0
Comp PAR =55
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =51
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =0
Comp PAR =96
COMP DEG  283.94
COMP DEG  286.81
COMP DEG  288.72
XLSB is clearly wrong in pressure and temperature because it should be between 0-240. Probably also lsb which is always 255.
Do you switch CS of the compass off, when measuring BMP280.
camerart
Joined Feb 25, 2013
3,842
X
Hi J,
In #24 the commented out sections, plus many more were tested, and there are so many combinations.
again, I've tried switching CS ON/OFF in many tests. From memory, in the working program they weren't switched ON/OFF between READs.
I've had a suspicion that XLSB and LB are the wrong way round. At the moment they are the same as the OSH working program.
C.
