Strange Behavior of battery
BobTPH
Joined Jun 5, 2013
11,678
Batteries do not stop. What is the voltage at the battery terminals when your system stops working? What makes it start working again?
My guess is a software problem with your Arduino, and it re-starts after cycling the power.
Bob
abc14
Joined Oct 15, 2017
123
Bob
Voltage is around 3.5 which suggest its not discharged fully. It restarts when I re-connect the battery.
BobTPH
Joined Jun 5, 2013
11,678
So when it stops the battery has mysteriously disconnected itself?
Or did you mean it restarts when you disconnect and then reconnect the battery.
Bob
BobTPH
Joined Jun 5, 2013
11,678
Okay, so what restarted it is rebooting your Arduino, which means it had likely gone astray. Could be a programming error, could be noise, could be a voltage drop when the 180mA device kicks in.
Bob
ArakelTheDragon
Joined Nov 18, 2016
1,366
I think its time you give us the circuit and exact motor specs.
By my calculations: 17A/h ÷ 64 days = 0.27A/h per day.
0.27A/h per day ÷ 24 hours = 0.011A
I hope I did not miscalculate something, but otherwise:
You are telling me that your entire Arduino plus servo motor have 11mA consumption?
