Steinhart equation problem..
Dodgydave
Joined Jun 22, 2012
11,395
ericgibbs
Joined Jan 29, 2010
21,551
hi D,
Is this clip the section you are referring too:
For example, assume a thermistor voltage divider circuit is connected to a 10 bit ADC. The beta constant for the thermistor is 3380, the thermistor resistance (R0) at 25°C is 10K ohms, and the ADC returns a value 366.
1/T = 1/298.15 + 1/3380 * ln((1023 / 366) - 1 )
1/T = 0.003527
T = 283.52K – 273.15K = 10.37°C
ericgibbs
Joined Jan 29, 2010
21,551
hi Dave,
An acronym for the solving order of an equation is BODMAS
Brackets, Of, Division, Multi, Add, Subtraction.
You should solve the deepest nested brackets first and then work out solving the inner most brackets as you go.
Does that help you.?
E
Dodgydave
Joined Jun 22, 2012
11,395
No it doesn't help me, i need to see it worked out in stages please, i keep getting the wrong result Eric.. If someone can show the steps and results thanks..
I tried 1023/366 then subtracted 1, i get 1.795, then I'm stuck!!
ericgibbs
Joined Jan 29, 2010
21,551
hi Dave,
This what Microsoft Math Calc shows.
I have also evaluated the 'ln' as a separate equation to show the steps.
Added to show this intermediate step.
ericgibbs
Joined Jan 29, 2010
21,551
hi,
Yes the natural ln value is 0.585 as you say.
You then multi that value by 1/3380 , which is 0.000296 * 0.585 =0.000173
Now add 1/298.15 , which is 0.00354 so that total is 0.00354 + 0.000173 = 0.003527
E
Dodgydave
Joined Jun 22, 2012
11,395
BINGO!, i kept adding the two fractions first, then multiplying by the Log,
,i realise now you add the first one ( 1/298.15) only. Thankyou.. D
