Small-signal ac equation associated with the inductor
samiulawh
Joined Aug 1, 2025
In the following, you can see three images. You can see my solution as well as the correct answer. Can you tell me how and from where the highlighted factor come?
Irving
Joined Jan 30, 2016
5,195
Without working it through in detail, I'd say that the term referenced is related to the output voltage ripple due to the Vout drop during the 'on' time and the Vout rise during the 'off' time (hence the R v Ron ratio).
