MisterBill2
- Joined Jan 23, 2018
- 28,111
OK, with two adjustable VRs it should be possible to add current control quite simply. It will be needed to be able to add a parallel resistance to set the second current level, that might be as simple as tacking on a photo-resistor with an LED to control it.Then even a 555 timer could control the operation.
