Start capacitor needed for 1957 single phase electric motor
MaxHeadRoom
Joined Jul 18, 2013
30,807
I would start with at least a 20μf to 40μf motor start rated.
If you obtained a couple of 20μf you could test using single, parallel, series combo to get in the ball park, if it is a start capacitor, it is only in circuit for a few seconds just to initiate rotation.
Are you sure it is just start cap type, or start/run type? i.e. in circuit all the time.
Max.
Big Chevy
Joined Oct 7, 2018
Max.
Thank you for your help will try this today. The starting bindings on this motor are controlled by a mechanical centrifugal switch unit so all should be good with running start capacitor type thank you again.
