Hi everyone,
I am actually writing to you because I would need to shed some light on start and run capacitors.
I am working in automatic doors and most of the single phase motors with work on have capacitors (just one per motor).
Up to recently, I have always thought that those capacitors were start capacitors because I was taught this by the most experienced engineers in work and it also very common to say that capacitors help the motor to start so for me it was just making sense.
However, I have recently realised there were loads of confusion between start and run capacitors and not a lot of people can actually make the difference and identify them properly. I went to a electronic component retailer last week and the guy at the counter didn't know the difference and could only read what was on his catalogue.
But what really confused me was that I went on a job last week where there was a gate on which the left motor would hum and not move, after checking visually the caps. I quickly noticed that its cap was melted at the bottom and some grey matter has come out and gone hard.
Reading the motor technical manual, they are talking about a starting capacitor however following the spec of the cap and the motor, I believe it is actually a run capacitors and not a start capacitor.
So now, I am interested to hear your opinions and would appreciate if you could (un)confirm my findings/believes.
Motor spec:
FAAC 400 (hydraulique ram)
Max Traction / Thrust Force: (daN) 620
Effective Rod Stroke: (inches) 10 1/4
Linear Rod Speed: (inches/sec) 0.4
Operator Weight: (lbs) 19
Use Frequency: (cycles/hour) 70
pump Flow-Rate: (liters/min) 1
Hydraulic Locking: (1) = Closing (2) = Opening and Closing (1)
Max Leaf Length: (feet) 16
Power Supply 115 VAC ± 10% or 230 VAC +6% -10% 50/60 Hz.
Absorbed Power (W) 220
Absorbed Current (A) 1 (230V) or 2 (115V)
Electric Motor (rpm) 1400 - 4 poles
Thermal Protection on Winding (°F) 248°
Thrust Capacitor 25uF / 115 V or 8uF / 230 V
Ambient Operating Temperature Range (°F) - 4° to 131° Protection Class IP55
As you can see there are talking about a thrust cap but in another paragraphe of the manual they mention it as a starting cap.....
But if I follow the identification process, it comes up as a run cap.
Very confusing indeed!
The cap spec are:
8mfd -+5%
AC 400V B 25/85/21
AC 450V C 25/85/21
50/60 Hz
thanks
Motor spec:
The cap spec are:
8mfd -+5%
AC 400V B 25/85/21
AC 450V C 25/85/21
50/60 Hz
thanks
