the reading I taken, was with diode modethe voltmeter is beeping
when you said check the voltage, do you mean change the meter from diode to volts?
If the meter was beeping in the Diode mode when checking Q8 then the transistor is most like shorted.the reading I taken, was with diode mode
[/QUOTE
give 20minIf the meter was beeping in the Diode mode when checking Q8 then the transistor is most like shorted.
I would remove Q8 and test again in the Diode mode.
Done! it's damaged as it beep even from out of the board
Ok, thank you very much for everything you done! You r great! Speak to you soon. Have nice dayOK. Need to order replacement. I would also get new MPSA29 as I don't trust the transistors you have now. Get two of each.
We can continue the session when they arrive. Please do not replace or install anything until we can continue.
Also a LM13600 for that small board if you want as I believe that is the culprit.
Hi bro, I just wanted to let you know that I have the transistors but not the LM13600. the seller did send it, but still is not with me, if it will not arrive by tomorrow, he will send another one. In the main time could we procede without it? Let me know when you will be available. Thank you in advanceOk, thank you very much for everything you done! You r great! Speak to you soon. Have nice day
Sorry my friend, I was out, just got home! If too late now don't worry, we do it when you can, but i'm here and readyReady when you are.
ciao, no I didn't install them because you told me to wait, the board is out, and it will take about 30 mins to install everything and put the board inNow is OK.
Just to recap, Q8 and Q2 are not installed at this time correct?
I'll do it now tho, will take less then 30 minsciao, no I didn't install them because you told me to wait, the board is out, and it will take about 30 mins to install everything and put the board in
Fuck, i read this now, sorry I have already done! But I did test them today all 4 have the same value and let the current pass only in one sideNot yet, need to test Q2 and Q8 before installing.
I don't trust any parts ordered on Ebay.
If you need to know the value, i can test the other 2, which they were the same value of the 2 that I have installed nowi read this now, sorry I have already done! But I did test them today all 4 have the same value and let the current pass only in one side
I tested them by put the red prob to the center leg (base) and touch he other 2 (E, C) with the black than I did the revers, in one way the current flow but on the other does notYes please. Did you test with the DIODE function and How?
