SR technology jam 150 plus (Schertler) keep burning resistor R2
sghioto
Joined Dec 31, 2017
8,751
Normally at this point with the mixer board disconnected I would test the audio output amps by injecting an audio signal to their inputs. You probably don't have this piece of equipment but usually can jury rig something using the headphone output of a phone or battery operated radio. We can discuss this when you have time.
Cesco77
Joined May 23, 2022
307
Hi bro! Sorry for today, I get an important call from the vet, I have to answer, I have been on the phone for too long and I manage to be late for work, so I have to rush! Apology for not answer. I found out this: I did start it (couldn't resist) and it didn’t burn the R2! I have been able to play music! (so the amp output work, both) But then I do realise that I didn’t attach the little board that is connected to the J8, as soon I did attach it, after starting, I saw smoke close to the leg of Q10, I did disconnect it very quickly, as result i'm not sure were this smock was coming from! I did detach it from the board again (the little board) and it is “working” (look like/kind of) Is tay on and it play music...Now why is "working" without that small board? What is this board for? I'm apology for my ignorance but I'm usually fix television phone etc (and I should continue to do so) so I'm not familiar with amplifier... This little board is not on the schematic! This perhaps eliminate the mixer as faulty candidate? I thinking that is this board that make the problem, or something relate to it. Do you have any idea what is this board for? Thank you
Cesco77
Joined May 23, 2022
307
You are exactly correct that's where the problem is. Will need to research that board.
Can you get some better photos
Hello! here is the pictures you asked
Cesco77
Joined May 23, 2022
307
I notice that on the schematic, there are 6 IC (TL072) but on the board I have only 4! so you were right when you said that this schematic it's not for the plus. (or this board is not the plus, (but on the amp it's say plus) Anyway, I checked many resistor in the little board, but I can't find anything. More than the little board faulty, I suspect something relate to it on the main board, the "only" direct connection with TDA, (the TDA was the cause of all this i thing) I see here, is on pin 7 which is connect to pin 3 at the TDA, checked many component around there but nothing obvious.....
