SR technology jam 150 plus (Schertler) keep burning resistor R2
sghioto
Joined Dec 31, 2017
8,751
OK. Now on the mixer board there are 12 diodes configured the same way I would like to check as you just did with D21-22.
They are D9 through D20. I am looking for a short or very low reading measuring both ways.
Cesco77
Joined May 23, 2022
307
to get the mixer board out will take me ages, it has plenty of knob that need to be out, and lots of screw to be unscrewed! Why should be something wrong with the mixer? I haven't touch it! Sorry I haven't see your last post, ok now I got it, but is this necessary?
Cesco77
Joined May 23, 2022
307
can it be done without get the board out? I'm not lazy, I haven't got the time at 3.30 i have to go work
sghioto
Joined Dec 31, 2017
8,751
Good. I'm trying to isolate the -12 volt supply to see where the problem might be.
Can you get to those diodes without removing the mixer board?
Cesco77
Joined May 23, 2022
307
Good. I'm try to isolate the -12 volt supply to see where the problem might be.
I can't see where they are without removing it, also I remember that this board has no symbol on the component so very difficult to identify (for me) and the schematic we have is different from the design of this board, very confusing
sghioto
Joined Dec 31, 2017
8,751
OK. From the schematics if they are correct the -12 volt supply is only to power the op amps on the mixer and main amp pc boards.
You can reinstall the 10 ohm resistor R2, disconnect the mixer board and we will see if the -12 volt supply will work.
Other option is to order several 1K 5 watt resistors to use for testing later when they arrive.
Cesco77
Joined May 23, 2022
307
ok, I'm going to reinstall the R2
Cesco77
Joined May 23, 2022
307
i got it done
