Its acting same2)i ll try as soon as i can and i let you know.
Try a large bypass cap from that cable to GND, or use a seperate power supply for the mosfets just to see if that is the problemWhen i remove the voltage cable of mosfets, the signals are coming back to the normal. But when i replug the cable of 1-3th mosfets drain's , the signals are acting anormally as i told above.
oui monsieur ! im pretty sure its correctIs the diode from Vcc to Vb connected the right way round?
my power supply is good. Scoped lots of times and there is no peaks. Its pure dc voltage.Try a large bypass cap from that cable to GND, or use a seperate power supply for the mosfets just to see if that is the problem
