salut everyone !
I have some problems about triggering mosfets. The main object is control a full bridge maded by mosfets which is irfz44n in this case.
When i plug the bridge configuration gates cable through the signal cable (signals coming from ir2101,25kHz) ,the signals are changing anormal ! Like this;
When i remove ch2 signal from breadboard ,this one is happening;
Aftet i remove ch2 signal, the output is not changing. Its so much anormal dont know why !
İs there any idea ?
İs there any idea ?
