Spice simulation and negative voltage
noweare
Joined Jun 30, 2017
115
This SPICE simulation shows the output voltage going below ground.
Is this correct. The op amp is single ended and I would of thought the waveform
would be clipped at ground and not show the negative swing. Is this correct ?
38,521
Look directly at the opamp output and you will see that it doesn't go below ground.
Edit: Note that in your circuit R5 is in parallel with R6 so you could combine them into one resistor of the appropriate value.
noweare
Joined Jun 30, 2017
115
@crutschow didn't notice that, thanks. The voltage divider sets the bias and the R6 is supposed to be a return current to ground. R6 through off the bias a bit. Looking the output of the op amp... the ac is riding on the bias so no negative swings. But after the capacitor that negative voltage (in real life) should be clipped at ground, correct?.
@OBWOB49 yes, you are correct but the waveform, if I looked at it on a scope would only go to ground. Maybe it's just a SPICE thing?
@ dana - I removed the extra source, but it didn't make a difference.
38,521
Not correct.
Why would it clip the negative voltage any more than it would clip the positive voltage.
Ground has no polarity.
The capacitor removes the dc bias at the output of the op amp so the capacitor output has a DC average of zero volts.
For that to happen, the output waveform must equally go above and below ground, as you observed.
It's definitely not a "SPICE thing" and you will see the exact same waveform with an oscilloscope in real life.
noweare
Joined Jun 30, 2017
115
For some reason I was thinking the ground of the load resistor would cause the ac signal to clip the same as an op amp who's negative
supply terminal was grounded (and ac signal not biased).
But I think I understand how it works. The full sinewave is present since the op amp is biased. Running it through the cap just shifts the average around ground (0 volts). Thanks
