No. The reason your output is going below ground is that capacitor C2 has removed the DC component from the signal at the output of U1, leaving only the AC component.Is this correct ?
Not correct.But after the capacitor that negative voltage (in real life) should be clipped at ground, correct?.
Correct.But I think I understand how it works. The full sinewave is present since the op amp is biased. Running it through the cap just shifts the average around ground (0 volts).
by Duane Benson
by Duane Benson
by Jake Hertz
by Jerry Twomey
