SPI Programming using STM32F407xx MCU
EngineerRod
Joined Dec 11, 2022
7
I am looking for a debuging solution to implementing the STM32F407xx Discovery Board in the configuration of SPI Tx Master. I am enrolled with udemy taking the bare metal driver development course. My current project requires that I set my discovery board in Tx Master Mode (MSTR, SSI, and SSM set to HIGH) with MOSI configured to deliver the "Hello World" test transmission. No slave node is to be used and NSS is left hanging. Software Select is chosen to establish communication. I am using the EasySync USB Logic Analyzer to monitor activity on SCK(PA5) and MOSI(PA7) GPIO lines configured with alternate functionality. My logic analyzer detects no data or clock activity. Using STM32CubeIDE show all registers are configured and working. I'm not sure what is missing in the configuration. I have included my files for review. Any suggestion would be greatly appreciated.
Thanks,
Rodney
35,065
Welcome to AAC!
I am an experienced STM32 user and will be able to help you.
It would be easier for me if you posted your text code directly into your post. I will have a look tomorrow.
Use code tags like this:
[code=C] … your code goes here … [/code]
Post one file for now beginning with main.c.
35,065
Assuming that you are using STM32CubeIDE, have you been able to successfully make an LED flash?
Do you have access to an oscilloscope?
EngineerRod
Joined Dec 11, 2022
7
Welcome to AAC!
Thanks for the Welcome. Below you can find my code to test whether data is being sent over MOSI. My earlier projects were
successful in making the on board led blink via GPIO Pins but no similar success using the SPI peripheral with no subnode.
My Code:
C:
* 006_SPI_SendTest.c
/** Setup
* SPI2_NSS  --> PB12 AF5
* SPI2_SCLK --> PB13 AF5
* SPI2_MISO --> PB14 AF5
* SPI2_MOSI --> PB15 AF5
#include <stdint.h>
#include <string.h>
#include "stm32f407xx_gpio_driver.h"
#include "stm32f407xx_spi_driver.h"
void PinInit()
    // Configure MOSI Pin
    GPIO_Handle_t spiPin;
    memset(&spiPin, 0, sizeof(spiPin));
    // Both pins share similar configurations
    spiPin.pGPIOx = GPIOB; // stm32f407xx.h --> line 191 --> #define GPIOB     ((GPIO_RegDef_t*) GPIOB_BADDR)
    spiPin.GPIO_PinConfig.GPIO_PinMode = GPIO_MODE_ALTFN;
    spiPin.GPIO_PinConfig.GPIO_PinAltFunMode = BIT5;
    spiPin.GPIO_PinConfig.GPIO_PinOPType = GPIO_OUTPUT_TYPE_PP;
    spiPin.GPIO_PinConfig.GPIO_PinSpeed = GPIO_SPEED_FAST;
    spiPin.GPIO_PinConfig.GPIO_PinPuPdControl = GPIO_PUPD_NONE;
    // Setting up MOSI pin
    spiPin.GPIO_PinConfig.GPIO_PinNumber = BIT15;
    GPIO_Init(&spiPin);
    // Setting up SCLK pin
    spiPin.GPIO_PinConfig.GPIO_PinNumber = BIT13;
    GPIO_Init(&spiPin);
int main()
    PinInit();
    // Configure spi2 for master communication
    SPI_Handle_t spi2;
    memset(&spi2, 0, sizeof(spi2));
    spi2.pSPIx = SPI2;
    spi2.SPIConfig.SPI_BusConfig = SPI_BUS_CFG_FULLD;
    spi2.SPIConfig.SPI_DeviceMode = SPI_DEVICE_MODE_MASTER;
    spi2.SPIConfig.SPI_Speed = SPI_CLK_SPEED_DIV2; //
    spi2.SPIConfig.SPI_DFF = SPI_DFF_MODE_8BIT;
    spi2.SPIConfig.SPI_CPHA = SPI_CLKPHA_LOW;
    spi2.SPIConfig.SPI_CPOL = SPI_CLKPOL_LOW;
    spi2.SPIConfig.SPI_SSM = SPI_SSM_ENABLE;
    SPI_Init(&spi2);
    // Manually setting SSI to high to avoid modf error.
    SPI_SSIConfig(spi2.pSPIx, ENABLE);
    spi2.pSPIx->SPI_CR2 |= (1 << 2);
    //spi2.pSPIx->SPI_CR1 |= (1 << 14);
    // Enable device after configuration
    SPI_SetupDevice(spi2.pSPIx, ENABLE);
    // Send data
    char buff[] = "Hello World";
    SPI_SendData(spi2.pSPIx, (uint8_t*)buff, strlen(buff));
    while (1)
        /* code */
    return 0;
35,065
I created a new project for the STM32F407G-DISCO1 using STM32CubeIDE version 1.10.1.
Without worrying about the SPI setup, this is the main.c generated.
C:
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * Copyright (c) 2022 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "usb_host.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
I2C_HandleTypeDef hi2c1;
I2S_HandleTypeDef hi2s3;
SPI_HandleTypeDef hspi1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_I2C1_Init(void);
static void MX_I2S3_Init(void);
static void MX_SPI1_Init(void);
void MX_USB_HOST_Process(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_I2C1_Init();
  MX_I2S3_Init();
  MX_SPI1_Init();
  MX_USB_HOST_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    MX_USB_HOST_Process();
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 336;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 7;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    Error_Handler();
  * @brief I2C1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN I2C1_Init 0 */
  /* USER CODE END I2C1_Init 0 */
  /* USER CODE BEGIN I2C1_Init 1 */
  /* USER CODE END I2C1_Init 1 */
  hi2c1.Instance = I2C1;
  hi2c1.Init.ClockSpeed = 100000;
  hi2c1.Init.DutyCycle = I2C_DUTYCYCLE_2;
  hi2c1.Init.OwnAddress1 = 0;
  hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
  hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
  hi2c1.Init.OwnAddress2 = 0;
  hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
  hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
  if (HAL_I2C_Init(&hi2c1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN I2C1_Init 2 */
  /* USER CODE END I2C1_Init 2 */
  * @brief I2S3 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN I2S3_Init 0 */
  /* USER CODE END I2S3_Init 0 */
  /* USER CODE BEGIN I2S3_Init 1 */
  /* USER CODE END I2S3_Init 1 */
  hi2s3.Instance = SPI3;
  hi2s3.Init.Mode = I2S_MODE_MASTER_TX;
  hi2s3.Init.Standard = I2S_STANDARD_PHILIPS;
  hi2s3.Init.DataFormat = I2S_DATAFORMAT_16B;
  hi2s3.Init.MCLKOutput = I2S_MCLKOUTPUT_ENABLE;
  hi2s3.Init.AudioFreq = I2S_AUDIOFREQ_96K;
  hi2s3.Init.CPOL = I2S_CPOL_LOW;
  hi2s3.Init.ClockSource = I2S_CLOCK_PLL;
  hi2s3.Init.FullDuplexMode = I2S_FULLDUPLEXMODE_DISABLE;
  if (HAL_I2S_Init(&hi2s3) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN I2S3_Init 2 */
  /* USER CODE END I2S3_Init 2 */
  * @brief SPI1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN SPI1_Init 0 */
  /* USER CODE END SPI1_Init 0 */
  /* USER CODE BEGIN SPI1_Init 1 */
  /* USER CODE END SPI1_Init 1 */
  /* SPI1 parameter configuration*/
  hspi1.Instance = SPI1;
  hspi1.Init.Mode = SPI_MODE_MASTER;
  hspi1.Init.Direction = SPI_DIRECTION_2LINES;
  hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi1.Init.NSS = SPI_NSS_SOFT;
  hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;
  hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi1.Init.CRCPolynomial = 10;
  if (HAL_SPI_Init(&hspi1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN SPI1_Init 2 */
  /* USER CODE END SPI1_Init 2 */
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOE_CLK_ENABLE();
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(CS_I2C_SPI_GPIO_Port, CS_I2C_SPI_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(OTG_FS_PowerSwitchOn_GPIO_Port, OTG_FS_PowerSwitchOn_Pin, GPIO_PIN_SET);
  HAL_GPIO_WritePin(GPIOD, LD4_Pin|LD3_Pin|LD5_Pin|LD6_Pin
                          |Audio_RST_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pin : CS_I2C_SPI_Pin */
  GPIO_InitStruct.Pin = CS_I2C_SPI_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(CS_I2C_SPI_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : OTG_FS_PowerSwitchOn_Pin */
  GPIO_InitStruct.Pin = OTG_FS_PowerSwitchOn_Pin;
  HAL_GPIO_Init(OTG_FS_PowerSwitchOn_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : PDM_OUT_Pin */
  GPIO_InitStruct.Pin = PDM_OUT_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  GPIO_InitStruct.Alternate = GPIO_AF5_SPI2;
  HAL_GPIO_Init(PDM_OUT_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : B1_Pin */
  GPIO_InitStruct.Pin = B1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_EVT_RISING;
  HAL_GPIO_Init(B1_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : BOOT1_Pin */
  GPIO_InitStruct.Pin = BOOT1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  HAL_GPIO_Init(BOOT1_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : CLK_IN_Pin */
  GPIO_InitStruct.Pin = CLK_IN_Pin;
  HAL_GPIO_Init(CLK_IN_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : LD4_Pin LD3_Pin LD5_Pin LD6_Pin
                           Audio_RST_Pin */
  GPIO_InitStruct.Pin = LD4_Pin|LD3_Pin|LD5_Pin|LD6_Pin
                          |Audio_RST_Pin;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  /*Configure GPIO pin : OTG_FS_OverCurrent_Pin */
  GPIO_InitStruct.Pin = OTG_FS_OverCurrent_Pin;
  HAL_GPIO_Init(OTG_FS_OverCurrent_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : MEMS_INT2_Pin */
  GPIO_InitStruct.Pin = MEMS_INT2_Pin;
  HAL_GPIO_Init(MEMS_INT2_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
EngineerRod
Joined Dec 11, 2022
7
C:
  * @file           : main.c
  * @attention
#include "main.h"
  * @retval int
int main(void)
  HAL_Init();
  MX_GPIO_Init();
  MX_I2C1_Init();
  MX_I2S3_Init();
  MX_SPI1_Init();
  MX_USB_HOST_Init();
  /* Infinite loop */
  while (1)
  * @retval None
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
    Error_Handler();
  * @param None
  * @retval None
    Error_Handler();
  * @param None
  * @retval None
    Error_Handler();
  * @param None
  * @retval None
                           Audio_RST_Pin */
                          |Audio_RST_Pin;
  * @retval None
  __disable_irq();
  while (1)
  * @retval None
I'm not familiar with HAL. I've read briefly on the subject. Udemy is offering a bare metal driver microcontroller course. 1st project is configuring SPI Master with no Slave node attached. We are only configuring SCK and MOSI pins. NSS is software configured via SSI and SSM bits in the SPI_CR1. Our task is to send "Hello World" via MOSI with a 8-bit DFF. Signal is monitored using logic analyzer on PB13(SCK) and PB15(MOSI)
EngineerRod
Joined Dec 11, 2022
7
Are you generating the code as an STM32CubeIDE Project or Empty Project?
35,065
Ignore the SPI requirement for now. Get HAL configured properly. It will save you a lot of headaches.
I am generating code for an STM32CubeIDE project.
EngineerRod
Joined Dec 11, 2022
7
Are the other functions required for me to get every thing running or is this a starting point before every thing
is finalized?
Should I run this code or continued to build upon it?
35,065
is finalized?
No. Don’t bother to run this code. This is just an example of what STM32CubeIDE generated code should look like.
You need to step back and do the same thing with your STM32CubeIDE.
Generate code to make an LED flash. After that we can move on to other things. If you get stuck I can help you along.
If you don’t know how to get to this stage I can guide you one step at a time. I have a tutorial on this somewhere.
Edit: Check this out.
