Hi! I am trying to establish a SPI communication with an LIS2DE12 accelerometer. First, I would like to say that I have checked phase, polarity, msbFirst and CS. I am using an EM9304 as the master of the communication, and the spi clock frequency is aproppriated.
Writing or reading from the sensor, makes it sends an weird symmetrical waveform in to MISO pin.
(This symmetrical waveform is equal to the LIS2DE12 ID (0X33 = 00110011), but I don't know if its a coincidence.)
I had tried many different registers (writing and reading) and the sensor only send this signal. I read both datasheets and couldnt figure how to make it work or get to the conclusion that I have a hardware problem.
- MOSI Signal
https://imgur.com/a/mNf0r0y
- MISO Signal
https://imgur.com/a/EGDG0Pv
These are the prints from the oscilloscope with the MOSI and MISO signals. In the MOSI print, I am sending a write commando to CTRL_REG4 (0x23) and an 8bit data (0x34). In the following pack of bytes, I am trying to read te content of this same register (CTRL_REG4). As you can see, the module keeps sending 0x33 through MISO.
Thanks in advance for any kind of help! Bye.
