Speed control for blender
lotusmoon
Joined Jun 14, 2013
232
The digital display on my blender is broken. I don't want to deal with the company as they are very problematic.
Instead of the digital display I just want to add a manual on-off button and the speed variation dial.
I'm new to electronics but I guess the speed dial is a potentiometer.
The motor just has 3 wires to it a positive, negative, and earth. So I guess to lower the speed you reduce the power input.
This is the motor I have put a couple of pictures below –
Blender motor
zhongshan lovas Electric 9550
220 – 240 v 1500 watts
F class 155
APPlianceCO.,Ltd
lotusmoon
Joined Jun 14, 2013
232
That is a brushed Universal (AC/DC) motor, normally there is a Triac set up to vary the RPM's.
thank you for letting me know that. There are printed circuit boards there at the minute with a digital display I have no idea what any of it is. Is it possible for me to buy a Triac set up with a turning volume dial to vary the RPM's ?
lotusmoon
Joined Jun 14, 2013
232
Thank you so much is this the one ? that is so helpful
1pcs AC 220 V 2000 W SCR Voltage Regulator Dimming Dimmers Speed Thermostat Controller
The motor is 1500 watts
lotusmoon
Joined Jun 14, 2013
232
Thank you for your help - Would this one be better for peak currents in the motor - 4000W 220V AC SCR Motor Speed Controller Module Voltage Regulator Temperature Dimmer for Electric Furnace Water Heater LED Light
