I would suspect this one. Teeda, you may find the information in this pdf of interest.Which board exactly?
Spartan-3EWhich board exactly?
Ya, is tis one.
Is there anny reason as to why you wish to avoid using PicoBlaze?but if possible, i wish to avoid of using PicoBlaze.
cause my project supervisor (lecturer) said that, when involve with PicoBlaze, it will be more difficult to use or to write the program. Hence he recommend that don't use the PicoBlaze.Is there anny reason as to why you wish to avoid using PicoBlaze?
If you are looking to implement the LCD dislay using hardware you will probably need to look at implementing a memory sub-system that holds your characters that you will be displaying on the LCD as well as a series of control signals to drive the LCD display.
Dave
