I cannot seem to program the ATtiny84a with Atmel Studios 7 with an Arduino Uno as the programmer. I got Atmel Studios 7. I opened the Sparkfun Servo Trigger solution. It asked me to upgrade or something so I said yes. I do not have a programmer but I do have an Arduino Uno with an ATMEGA328P chip. I uploaded the example ArduinoISP code to the Uno with no code changes.
Now in Atmel Studios, I went to Project>Device>ATtiny84A.
Then, I created an external tool with the arguments:
I connect the Arduino Uno pins 5v, GND, and 10-13 to the ISP pins on the ServoTrigger board.
What happens now is annoying.
But then I remove the 10uF cap, it works. But sometimes it does work with the capacitor... It's confusing. Sometimes I also need to click the Arduino reset button while uploading. Then it uploads. So just hitting the reset button on the Arduino fixes that problem. BUTTTT the next problem:
Once getting it to upload I get this:
I even override the check with -F and it uploaded again just without the check. It still seems to have not programmed the attiny84a though... So I am lost.
Code:
-p t84 -c arduino -P COM3 -b 115200 -v -D -U flash:w:"$(OutDir)Debug\$(TargetName).hex":i
Code:
System wide configuration file is "D:\avrdude-6.3-mingw32\avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude.exe: stk500_recv(): programmer is not responding
avrdude.exe: stk500_getsync() attempt 1 of 10: not in sync: resp=0xef
This goes on all the way to 10 and just says thank you at the end...
Code:
Using Port : COM3
AVR Part : ATtiny84
Chip Erase delay : 4500 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 6 4 0 no 512 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 8192 64 128 4500 4500 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude.exe: Device signature = 0x1e950f (probably m328p)
avrdude.exe: Expected signature for ATtiny84 is 1E 93 0C
Double check chip, or use -F to override this check.
avrdude.exe done. Thank you.
