Space is big, and magnetism is strong
  • Thread starter Deleted member 115935
  • Start date
Joined Dec 31, 1969
I woke again with a question
The earth has a magnetic field that shields us from nasty radiation,
It does not seem that strong at the surface
two questions,
a) I wonder how much power / magnetism would be needed to protect enough of a space ship to enable the crew to be protected ?
say 3m by 3m by 3m
b) inside a magnet, is there a north south ? i.e. if the space ship was "magnetised" some how, would all the ferrous bits inside get magnetised ?
BobTPH
Joined Jun 5, 2013
11,647
Simple explanation:
The earth’s field is weak, but extends over a large distance, so there is plenty of time for an incoming particle to be deflected.
You could not create such a large field around a spaceship, because it depends on the distance between the poles.
More details:
Magnets create a dipole field, which is a result of the two poles, (get it? Di-pole.) Dipole fields fall off at the cube of the distance for distances large compared to the distance between the poles.
Bob
Joined Dec 31, 1969
Simple explanation:
More details:
Bob
Does the strength of the magnetism affect the amount the particles would be deflected ?
So even of poles were only m apart, not Km,
I wonder how strong they would have to be to deflect "sufficient" what ever that is the particles.
