(SOLVED) Control solenoid valve with Arduino or with circuit
Sourc3
Joined Dec 2, 2021
81
hi Sourc
Check this simulation for -100C change over.
Do you follow it OK.?
I would recommend 0.1% tolerance resistors and R5 be 100 Ohm 20 turn trim pot, for calibrating.
E
Im reading, im reading, I dunno if I understand the graphic now, -120v? where is the change? 0.01ohm? Im trying but this last reply is a bit confused for me.
ericgibbs
Joined Jan 29, 2010
21,577
Hi S,
Read the Notation on the Plot NOT -120V, but -120C degrees, the scale is Degrees.
The switch On temperature for the relay is -100Cdeg rising , if you want the relay to switch Off at a lower than -101C, falling, reduce the value of R2.
What don't you understand about the plot.???
Sourc3
Joined Dec 2, 2021
81
Hi ericgibbs , I am here again for the holidays, now we are going to order nitrogen again and in these days finish your prototype, sorry for being absent but it was my holidays and I have completely disconnected.
[READY]
I don't have a 60 ohm res and 1Meg, I will use a 148 (100+48) ohm and a 500k ohm and try to test it with a heat gun.
Today I said you the results.
Sourc3
Joined Dec 2, 2021
81
Hi @ericgibbs , I had tested with the hot gun, I set the reference resistance in 120ohm, so when I heat it, the Vin((-V)-(+V)) is > 0 and the relay is ON (I have set the max amper in 40mA) and It's work, when it need to OFF again, it doesnt work. Anyway, this monday I will order the nitrogen and test it with your real values.
I needed a lot of time to understand the LM339 xd hahaha but thanks a lot, it only need a bit more work.
Sourc3
Joined Dec 2, 2021
81
@ericgibbs I have a question, the arduino mudule relay, have 3 pins (S, +, -), in my last circuit I join S with + and its work, do u think your circuit can resist that? What current do u calculate in transistor output? Im getting very high current.
ericgibbs
Joined Jan 29, 2010
21,577
hi S3.
Do you have a type number for your Relay Module or a link so that I check the details.?
E
@Sourc3
What is the voltage of your power supply and the working voltage of the relay module.?
Sourc3
Joined Dec 2, 2021
81
hi S3.
E
@Sourc3
If your module is of this type, they are only 5V relay coilsView attachment 275671
@ericgibbs I think I have it, I think this relay come with the diode and transistor like you posted.
So I have removed this part and it works, I have set 24 volts (To feed the solenoid too). And connect 24 volts to S(signal) and +(positive)
ericgibbs
Joined Jan 29, 2010
21,577
Hi S3,
Pleased to hear you have succeeded in making it work.
Let me know how it goes when you get the liquid nitrogen to carry out the final test. :)
E
Sourc3
Joined Dec 2, 2021
81
Hi S3,
E
Me too sir, thank you very much for your constant help. I'll send you a video when I have nitrogen and we can see it live.
Reloadron
Joined Jan 15, 2015
7,952
I worked with LN2 and you need a solenoid designed for LN2.
Way back in post #9 I mentioned that. Normally solenoids designed for cryogenics specify it in their data sheets. Does the label on the solenoid you show specify it works with LN? I had assumed you were already working with the LN2.
Ron
Sourc3
Joined Dec 2, 2021
81
Ron
Yeah @Reloadron , its a spececific solenoid for LN2. Thats no problem. We arent go to order LN2 yet, this task has been delayed until mid-October, so we don't go to order LN2 to test it.
